Component: Bitmap Drawer (Displays: Graphical)
| Version | 1.1 (Release) |
| Category | Displays: Graphical |
A component to simplify the process of drawing bitmap images to a graphical display. Stores the bitmap image inside a ROM look up table. Compatible with 24-bit Bitmaps and Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Use multiple BitmapDrawer components for multiple bitmap images.
Here is an example which loops drawing a monochrome and 24-bit bitmaps to the EBM001 graphical display.
The bitmap files used in the example can be found here.
Here is another example which overlays several monochrome images to give the impression of animation. Shows a pair of eyes, which can randomly and momentarily look left, right or blink.
Display_BMP
Draws the stored bitmap image onto the display at the coordinates specified.
The coordinates specify the upper left corner of the image.
- UINT X
- UINT Y
Display_BMP_With_Transparency
Skips over any pixels containing the transparent colour.
- UINT X
- UINT Y
- BYTE TransR - Red Colour Byte 0-255
- BYTE TransG - Green Colour Byte 0-255
- BYTE TransB - Blue Colour Byte 0-255
Simulation macro reference
gLCD Object
This property is of type Panel object and can be referenced with the variable name glcd_obj.
Graphical LCD Object to draw the bitmap image to
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file.
Bitmap file you wish to embed into the program
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth.
Number of bits per pixel.
Currently the component only supports bitmap files with 1-bit or 24-bit colour depth.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len.
The number of bytes of ROM the bitmap file will consume.
You can view the number of ROM bytes available on your target device using the Device Helper component.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth.
Width of the bitmap file in pixels
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight.
Height of the bitmap file in pixels
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset.
Offset in the file where the bitmap pixel data starts
ColourDisplay
This property is of type True or false and can be referenced with the variable name Colour_Display.
Automatically detects if the graphical LCD object is colour or monochrome
