Component: TCP Template (Comms: Networking)
| Author | Matrix Ltd. |
| Version | 1.4 (Release) |
| Category | Comms: Networking |
Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation. Suitable for inheriting
This component can be used as a base to create child components
The following components all inherit the traits of TCP Template:
| TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet.
Also available in the form of the version 1 EB023 E-block which uses the NM7010A module. | |
| TCP/IP component designed to work with the WIZ810MJ module from Wiznet,
as used on version 2 EB023 E-block and the MIAC Industrial Addon module. |
Additional examples can be found in the “Apps and Bundles” section of this Wiki:
Wireless LAN Application Guide
This component does not contain any downloadable macros
Simulation macro reference
TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE Channel
- Specifies the communications channel 0-3
RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE Channel
RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE Channel
- BYTE Byte1
- Specifies the value of the first byte
- BYTE Byte2
- Specifies the value of the second byte
- BYTE Byte3
- Specifies the value of the third byte
- BYTE Byte4
- Specifies the value of the fourth byte
SetPropertyVal
- <- STRING Property
- <- STRING Value
SetMyIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE IP0
- First Byte of IP address
- BYTE IP1
- Second Byte of IP address
- BYTE IP2
- Third Byte of IP address
- BYTE IP3
- Fourth Byte of IP address
TxSendString
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
- BYTE Channel
- <- STRING Data
- Data byte to append to Tx buffer.
RxSkipBytes
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE Channel
- BYTE Count
- Specifies how many bytes to skip
RxReadHeader
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE Channel
- BYTE Idx
- Specifies the byte index to return
CreateIPSocket
Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
- BYTE Channel
- BYTE Protocol
- Specifies which IP protocol to use
- BYTE Broadcast
- Allows broadcast type packets to be sent and received
SetDestination
This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
- BYTE Channel
- BYTE Dst_IP0
- Specifies the first byte of an IP address
- BYTE Dst_IP1
- Specifies the second byte of an IP address
- BYTE Dst_IP2
- Specifies the third byte of an IP address
- BYTE Dst_IP3
- Specifies the fourth byte of an IP address
- BYTE Dst_Port_Hi
- Port High Byte
- BYTE Dst_Port_Lo
- Port Low Byte
GetConsole
Obtain the console instance for the TCP/IP base.
TxStart
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE Channel
RxReadByte
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'RxReadByte' (or any other read function) will read the next byte
- BYTE Channel
CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
- BYTE Channel
- BYTE Src_Port_Hi
- Port High Byte
- BYTE Src_Port_Lo
- Port Low Byte
RxMatch_6_Bytes
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
- BYTE Byte4
- BYTE Byte5
- Specifies the value of the fifth byte
- BYTE Byte6
- Specifies the value of the sixth byte
RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
RxReadString
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE Channel
- BYTE Length
TxEnd
Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE Channel
CreateTCPSocket
This macro creates a socket for sending and receiving TCP data.
- BYTE Channel
- BYTE Src_Port_Hi
- Port High Byte
- BYTE Src_Port_Lo
- Port Low Byte
RxDataAvailable
This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
- BYTE Channel
TxSendByte
- BYTE Channel
- BYTE Data
TCPListen
This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
- BYTE Channel
RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE Channel
TCPConnect
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- BYTE Channel
- BYTE Dst_IP0
- BYTE Dst_IP1
- BYTE Dst_IP2
- BYTE Dst_IP3
- BYTE Dst_Port_Hi
- High Byte of destination port
- BYTE Dst_Port_Lo
- Low Byte of destination port
GetPropertyVal
RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE Channel
RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE Channel
TxSendMyMAC
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE Channel
CreateMACSocket
This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE Promiscuous
- Receive everything (1) or just data bound for your MAC (0)
- BYTE Broadcast
- Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE Error
- Allowsmessages with errors to be accepted (1) or rejected (0)
GetSocketStatus
This returns the state of the requested channel's socket.
- BYTE Channel
TCPClose
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE Channel
Hostname
This property is of type Line of text and can be referenced with the variable name hostname.
Local PC's hostname
Network Interface
This property is of type Fixed list of ints and can be referenced with the variable name interface.
List of network interfaces connected to the PC.
Sets which interface we are communicating via.
Gateway0
This property is of type Signed integer and can be referenced with the variable name gateway0.
Gateway IP address to the Internet, auto populated from the selected interface.
Gateway1
This property is of type Signed integer and can be referenced with the variable name gateway1.
Gateway2
This property is of type Signed integer and can be referenced with the variable name gateway2.
Gateway3
This property is of type Signed integer and can be referenced with the variable name gateway3.
Subnet0
This property is of type Signed integer and can be referenced with the variable name subnet0.
Network IP subnet mask, auto populated from the selected interface.
Subnet1
This property is of type Signed integer and can be referenced with the variable name subnet1.
Subnet2
This property is of type Signed integer and can be referenced with the variable name subnet2.
Subnet3
This property is of type Signed integer and can be referenced with the variable name subnet3.
IP0
This property is of type Signed integer and can be referenced with the variable name ip0.
Network IP address, auto populated from the selected interface.
IP1
This property is of type Signed integer and can be referenced with the variable name ip1.
IP2
This property is of type Signed integer and can be referenced with the variable name ip2.
IP3
This property is of type Signed integer and can be referenced with the variable name ip3.
MAC0
This property is of type Signed integer and can be referenced with the variable name mac0.
Network MAC address, auto populated from the selected interface.
MAC1
This property is of type Signed integer and can be referenced with the variable name mac1.
MAC2
This property is of type Signed integer and can be referenced with the variable name mac2.
MAC3
This property is of type Signed integer and can be referenced with the variable name mac3.
MAC4
This property is of type Signed integer and can be referenced with the variable name mac4.
MAC5
This property is of type Signed integer and can be referenced with the variable name mac5.
Target
This property is of type Panel object and can be referenced with the variable name notify_target.
Sets a target object, to which User.Notify events will be sent when data is sent and received.
Events are send with Message ID = this component's handle, Data: 1=Send, 2=Receive.
