FiniteStateMachine
Revision as of 09:11, 17 May 2017 by BenR (talk | contribs)
<sidebar>Sidebar: Flowcode Help Overview:Variables</sidebar>
Finite state machines are used all over the place in Flowcode components to keep track of things.
They are a means to allow a fixed number of deterministic states which can vastly simplify a program and is a great tool to add to your coding kit.
Techniques
A good technique when learning state machines is to try and break the task up into jobs and then try to implement those jobs in a orderly way.
E.g. making a cup of tea.
State 0 - Buy Ingredients - OK = State 1
State 1 - Fill Kettle With Water - OK = State 2 or Not Enough Water = State 1
State 2 - Boil Kettle - OK = State 3 or Not boiled yet = State 2
State 3 - Place teabag in cup - OK = State 4 or No Teabags = State 0
State 4 - Place milk in cup - OK = State 5 or No Milk = State 0
State 5 - Place boiling water in cup - OK = State 6 or Not filled yet = State 5 or Not Enough Water = State 1
State 6 - Stir the water - OK = State 7 or Not Stirred Enough State 6
State 7 - Cup of tea ready
As you can see making a cup of tea actually has a lot of stages and could be made much more complex, e.g. adding sugar, time to let the tea brew, milk before or after water....
FSM Example 1 - Simple comms parsing
Here is a very basic example.
We want to control a robot via a serial data connection. We control it by sending packets of 2 bytes.
The first byte is the value 'L' to signify the Left motor speed, the next byte is the motor speed 0-255.
The first byte is the value 'R' to signify the Right motor speed, the next byte is the motor speed 0-255.
The firmware for the robot could look something like this.
State Machine Example1
we always start at state 0, and we keep receiving bytes until the characters 'L' or 'R' are received. Once we receive one of the characters we know the next byte will be the corresponding motor speed so we can jump to the right state to collect and assign the value.
This would allow some fault tolerance. e.g. if the robot received a speed byte first then it would do nothing until the 'L' or 'R' bytes are received.
You could even control the Left motor without touching the Right motor by sending the 2 bytes packet starting with 'L' over and over again.
FSM Example 2 - Adding direction control
You could then expand the state machine if you wanted to by using a 3-byte packet and including the motor direction.
The first byte is the value 'L' to signify the Left motor speed, the next byte is the motor speed 0-255, the next byte is the direction 0-1.
The first byte is the value 'R' to signify the Right motor speed, the next byte is the motor speed 0-255, the next byte is the direction 0-1.
State Machine Example2
FSM Example 3 - Multi Mode Torch
Of course state machine don't just apply to comms, you could do a similar thing with a switch and a LED to make a multi-mode torch.
Start State 0 - Torch Off
Press 1 the torch turns on - State 1.
Press 2 the torch automatically flashes - State 2.
Press 3 the torch turns off - State 0.
State Machine Example3
FSM Example 4 - Multiple State Machines
Here is a project created to drive a pick and place component feeder bank.
The PC tells us when we need to move to the next component using a motor so we need to use a state machine to listen to and decode the incoming comms to detect when one of our feeder channels gets called up for action. When a valid feeder channel is detected we use a second state machine to start the motor moving and then after a delay to allow the motor to move we bring the motor back to the original start position. The second state machine has 8 tracking variables which allows us to control all 8 servo channels using the state machine. Using the state machines means that we are not having to use blocking code such as delays when moving the motors which means that multiple feeder channels can be in motion at once.
ServoFeeder
