Component: Slider control (Advanced Shapes)
| Author | Matrix Ltd |
| Version | 1.1 (Release) |
| Category | Advanced Shapes |
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications.
This component does not contain any downloadable macros
Simulation macro reference
GetValue
Gets the current value of the slider. This will be within the range set by the
SetRange macro.
SetValue
Set the current value of the slider. This will override any value set by using the mouse.
- FLOAT Value
- The value to set.
SetInteractive
Set whether the mouse can be used to change the slider value.
- BOOL Enable
- Set true to allow clicks to set scale
SetTitle
ShowScale
Set whether graduated marking are shown along the length of the slider.
- BOOL Show
- True to show scale, else false
SetRange
Set the minimum and maximum values that can be shown on the slider.
- INT Min
- Min (start) value
- INT Max
- Maximum (end) value
This component does not contain any properties
