Component: RFID (MFRC522) (Wireless)
| Author | Ben Rowland and STibor |
| Version | 3.0 (Release) |
| Category | Wireless |
 RFID (MFRC522) component
Functions designed to work with the MFRC522 contactless reader IC. The MFRC522 supports all variants of the MIFARE Mini, MIFARE 1K, MIFARE 4K, MIFARE Ultralight, MIFARE DESFire EV1 and MIFARE Plus RF identification protocols.
Here is a basic example program that reads the UID from a Mifare RFID tag and displays on an LCD.
 Display UID
Here is a basic example program to read and modify data on a Mifare RFID tag.
Display UID
 Read Write Test
Read Write Test
CompareUID
Compares the UID from the ReadCardSerial macro with 4 byte UID.
Returns 0 if the addresses match.
- BYTE Add0
- BYTE Add1
- BYTE Add2
- BYTE Add3
IsNewCardPresent
Is there a card present for us to communicate with.
Returns 0 for no card and 1 for valid card present.
GetType
Translates the SAK (Select Acknowledge) to a PICC type
- BYTE sak
- The SAK byte returned from PICC_Select
AntennaOff
Switches off the RFID antenna to save power.
The antenna must be switched on again before communicating with an RFID tag.
ReadCardSerial
Simple wrapper around PICC_Select.
Returns true if a UID could be read.
Remember to call PICC_IsNewCardPresent(), PICC_RequestA() or PICC_WakeupA() first.
The read UID is available in the class variable uid.
MifareWrite
Writes to a block of data on a MIFARE type tag
- BYTE BlockAddress
- BYTE Buffer
- BYTE BufferSize
Select
- BYTE ValidBits
StopCrypto
Used to exit the PCD from its authenticated state.
Remember to call this function after communicating with an authenticated PICC - otherwise no new communications can start.
MifareRead
Reads from a block of data on a MIFARE type tag
- BYTE BlockAddress
- BYTE Buffer
- BYTE BufferSize
Authenticate
This command manages MIFARE authentication to enable a secure communication to any MIFARE Mini, MIFARE 1K and MIFARE 4K card.
All keys are set to FFFFFFFFFFFFh at chip delivery.
The authentication is described in the MFRC522 datasheet section 10.3.1.9.
- BYTE Command
- PICC_CMD_MF_AUTH_KEY_A or PICC_CMD_MF_AUTH_KEY_B
- BYTE BlockAddress
- The block number
- BYTE Key
- Crypteo key to use
HaltA
Instructs a PICC in state ACTIVE(*) to go to state HALT
ReadUIDByte
- BYTE Index
- 0-9 = UID Data Bytes, 10 = UID Length, 11 = UID SAK
AntennaOn
Switches on the RFID antenna.
Called as part of the Initialise macro.
Initialises the RFID module ready for interaction with RFID tags.
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Reset
This property is of type Single digital pin and can be referenced with the variable name reset.
MFRC522 Reset Pin
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
