API Console.SetLineBytes
Revision as of 01:54, 12 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Writes a line of bytes from the given console, pass -1 for final line
Class hierarchy
Console
SetLineBytes
HANDLE ConsoleHandle
A valid console windows handle
ULONG Line
The zero-based index of the line to write the data to
BYTE[] Data
A block of data to add to the console
ULONG Offset
An offset into Data of the first byte to read from
ULONG MaxBytes
The maximum number of bytes to read, -1 for all
The default value for this parameter is: -1
  • Add to a calculation icon:
    ::Console.SetLineBytes(consolehandle, line, _arraydata, offset, maxbytes)
