Component: Slider control (Advanced Shapes)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Advanced Shapes |
Slider control component
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications.
Meters
| GetValue | |
| Gets the current value of the slider. This will be within the range set by the SetRange macro. | |
| [[File:]] - | Return |
| SetValue | |
| Set the current value of the slider. This will override any value set by using the mouse. | |
| [[File:]] - | Value |
| The value to set. | |
| SetInteractive | |
| Set whether the mouse can be used to change the slider value. | |
| [[File:]] - | Enable |
| Set true to allow clicks to set scale | |
| ShowScale | |
| Set whether graduated marking are shown along the length of the slider. | |
| [[File:]] - | Show |
| True to show scale, else false | |
| SetRange | |
| Set the minimum and maximum values that can be shown on the slider. | |
| [[File:]] - | Min |
| Min (start) value | |
| [[File:]] - | Max |
| Maximum (end) value | |
| SetMarks | |
| Decides on the presentation of the dial | |
| [[File:]] - | Marks |
| Number of marks on the dial | |
| [[File:]] - | Subs |
| Number of marks before a 'main' mark - can be zero | |
| ClearArea | |
| Clears the draw area | |
| SetRange | |
| Sets the min-max range to draw on the dial Used for setting the needle | |
| [[File:]] - | Start |
| [[File:]] - | End |
| SetGaps | |
| Sets the min-max of the span to draw on the X/Y marks Defaults are 0 and 1 | |
| [[File:]] - | End |
| SetJustify | |
| [[File:]] - | RAlign |
| True for right/top/outer alignment | |
| CalcAngle | |
| Decide the angle to display at given a range value | |
| [[File:]] - | RangeVal |
| SetPivotPos | |
| Sets the position of the object the lever rotates around | |
| [[File:]] - | PositionHandle |
| A handle to the position of the depressed location | |
| SetLatching | |
| Sets whether the button is depressed when the mouse is released | |
| [[File:]] - | Enabled |
| Unregister | |
| Removes the object to the list if present | |
| [[File:]] - | Target |
| SetMovementFor | |
| Sets the movement in units or PI/16 steps for the button | |
| [[File:]] - | Move |
| Movement to set to, default 4 | |
| Properties | |
| Connections | |
| Simulations |
