Component: Colour Sensor (EBM018) (EBM Modules)
Revision as of 09:41, 22 October 2018 by BenR (talk | contribs)
Version 1.1 (Release)
Category EBM Modules
Image Colour Sensor (EBM018) component
This board provides the ability to detect colours using the TCS3200 sensor. It will return RGB and W values, dependent on the colour of the object under test.
Sample program using the EBM018 - Colour sensor
Sets filter to RGB and W and reads values,displays on LCD
EBM018 Example
SetConfig
Sends the config data byte to the sensor using clock and data pins
BYTE Data
SetLEDOn
Turn on the White LEDs
This macro has no parameters
SetFrequencyRange
Dynamically change the sensor output frequency range to a new setting
BYTE Freq
Percentage range (2,20,100)
GetFrequency
Samples and returns the sensor output frequency (Hz)
UINT
SetFilter
Dynamically change the sensor filter to RGB or W.
Red = 0
Green = 1
Blue = 2
White = 3
BYTE FilterColour
Filter Colour; Red = 0, Green = 1, Blue = 2 and White = 3
SetLEDOff
Turn off the White LEDs
Initialise the sensor configuration as set by the component properties
Simulation macro reference
SDA
This property is of type Single digital pin and can be referenced with the variable name SDA.
Pin used for sending serial configuration data to the sensor device
SCL
This property is of type Single digital pin and can be referenced with the variable name SCL.
Pin used as clock pin for sending serial configuration data to the sensor device
Sensor Output
This property is of type Single digital pin and can be referenced with the variable name OP.
Pin used to monitor the output frequency from the light sensor
Output Frequency Range
This property is of type Fixed list of ints and can be referenced with the variable name FRQ.
Initial sensor output frequency range selection.
100% 0-500KHz
20% 0-100KHz
 2% 0-10KHz
Filter Option
This property is of type Fixed list of ints and can be referenced with the variable name FILTER.
Initial filter selected
LED Control
This property is of type Fixed list of ints and can be referenced with the variable name LED.
Initial White LED state
Sample Time Period
This property is of type Fixed list of ints and can be referenced with the variable name SAMPLE.
Length of time period used to sample the sensor frequency (longer is more accurate)
