| Author
Matrix Ltd.
| Version
2.1
| Category
Comms: System
Modbus TCP Master component
Modbus component for talking to Modbus compatible hardware via Ethernet or WIFI. Ensure TCP/IP or WIFI component is initialised and connected to a network before calling the ModbusMasterTCP component macros.
Example master program to control the slave. The example sets coil address 0, clears coil address 0, reads an input register and outputs to the LCD. Be sure to set the IP address of the slave device at the top of the program. If you are simulating then use the IP address of the PC running the Slave simulation. Both programs can be simulated on the same PC using two instances of Flowcode.
Modbus TCP Master Example
Example slave program to react to the signals from the master. The example listens for Modbus commands from the master and outputs the current coils 0 state to an LED connected to PortA. The input register is loaded with a value which is incremented on each Modbus transaction.
Modbus TCP Slave Example
Addressing
| Data Type
Common name
Starting address
Ending Address
Flowcode Start Address
Flowcode End Address
| Modbus Coils
Bits, binary values, flags
00001
10000
0
9999
| Digital Inputs
Binary inputs
10001
30000
0
19999
| Analog Inputs
Binary inputs
30001
40000
0
9999
| Modbus Registers
Analog values, variables
40001
60000
0
19999
ReadHoldingRegister
| This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
| The ID of the MODBUS slave
- UINT
RegAddress
| Address: 0=40001, 1=40002, ...
- UINT
RegCount
| Number of consecutive registers to read, starting from RegAddress
- BYTE
SetCoil
| This command writes the contents of a discrete coil at the location CoilAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- BYTE
SlaveID
- UINT
CoilAddress
| Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
- BYTE
CoilState
| 0=Off, 1=On
- BYTE
SetCoils
| This command writes the contents of a series of discrete coils at the location starting at CoilAddress through to CoilAddress + CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- BYTE
SlaveID
| The ID of the MODBUS slave - Used for TCP to Serial forwarders
- UINT
CoilAddress
- UINT
CoilCount
| Number of consecutive coils to try and read
- BYTE
CoilData
| An array of bytes each containing 8 1-bit coil values
- BYTE
GetResponseByte
| Reads a byte from the last received response. The Index parametes specifies which byte to read back.
- BYTE
Index
| 0=SlaveAddress, 1=FunctionCode/ExceptionCode, 2=DataBytes, 3=data0, 4=data1, ..
- BYTE
ReadCoils
| This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
CoilAddress
- UINT
CoilCount
- BYTE
GetResponseInt
| Reads a 16-bit value from the last received response. The Index parametes specifies the byte index of the value to read back.
- BYTE
Index
| 3=data0, 5=data1, 7=data2, ..
- UINT
SetHoldingRegisters
| This command writes the contents of several analogue output holding registers starting at the location RegAddress through to location RegAddress + RegCount . Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
| Number of consecutive registers to write, starting from RegAddress
- UINT
RegValue
| Array of values to send to the registers
- BYTE
SetHoldingRegister
| This command writes the contents of a analogue output holding register at the location RegAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegValue
| Value to send to the selected register
- BYTE
ReadAnalogInput
| This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
RegAddress
| Input Address: 0=10001, 1=10002, 2=10003, ...
- UINT
RegCount
| Number of consecutive inputs to read, starting from RegAddress
- BYTE
SetTCPAddress
| Sets the address of the remote TCP Slave that we wish to control.
- STRING
Address
| e.g. "192.168.1.1"
ReadDigitalInputs
| This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
DataAddress
- UINT
DataCount
- BYTE
SetHoldingRegister
| Sets the state of a single holding register.
- UINT
Address
| Coil Address
- UINT
Value
| Analogue Value range 0 - 65535
ReadAnalogInput
| Reads the value of a single analogue input.
- UINT
Address
| Coil Address
- UINT
ReadDigitalInputs
| Reads the state of a single digital input. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
| Coil Address Range 0 to (NumCoils - 1)
- BYTE
AddressCount
| Range 1-8
- BYTE
SetAnalogInput
| Sets the state of a single analogue input.
- UINT
Address
| Coil Address
- UINT
Value
| Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0. Returns 1 if USB is started ok.
| [[File:]] -
SetAnalogInput
- UINT
Address
| Coil Address
- UINT
Value
| Initialises the MIDI component and sets up the UART.
ReadAnalogInput
| Reads a single digital input.
- BYTE
- UINT
CommsBaud
| Sets the Baud rate of the alt communications channel
- BYTE
Baud
| Range: 0-7 : 0=1200 / 7=115200
LCDOptions
| Controls some of the LCD options
- BYTE
Foreground
| Range: 0-1
- BYTE
Background
| Range: 0-1
- BYTE
Transparent
| Range: 0-1
LCDVerbose
| Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
- BYTE
Mode
| Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
ReadDigitalInput
- BYTE
- BYTE
PWMConfig
| Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
- BYTE
| Range 0-1
- UINT
Period
| Range: 0-65535
- BYTE
Scaler
| Range: 0-3
PWMEnable
| Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
| Range 0-63 or 0b00000 to 0b111111
PWMDuty
| Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
- BYTE
| Range 0-5
- UINT
Duty
LCDCursor
| Sets the cursor position for the MIAC display
- BYTE
X
| Range: 0-21
- BYTE
Y
| Range: 0-4
WriteTran
| Allows a single transistor output to be switched on or off.
- BYTE
| Range 1-4
- BYTE
Value
| 0 = Off, 1 = On
LCDClear
| Clears the MIAC display
Network Comms Component
| Redirects communications via the selected component allowing different TCP/IP modules with different macros to work.
Status
| Shows the state of the network comms component to verify everything is configured correctly.
TCP/IP Port
| Port used for network communications Range: 0-65535
Receive Buffer Size
| Maximum number of bytes the receive buffer can hold
Receive Timeout
| Maximum time to wait for network reply, in mS
| A text label to appear on the Modbus panel object.
Simulations
