Component: WIFI (BL0136) (E-blocks 2)
| Author | Matrix Ltd. |
| Version | 2.1 (Release) |
| Category | E-blocks 2 |
- 1 WIFI (BL0136) component
- 2 Examples
- 3 Downloadable macro reference
- 3.1 DisconnectFromSSID
- 3.2 SendString
- 3.3 ClientConnect
- 3.4 ControlTCPServer
- 3.5 GetFirmwareVersion
- 3.6 CheckForPageRequests
- 3.7 ClientSendRequest
- 3.8 ReadSSIDFromScan
- 3.9 CreateAccessPoint
- 3.10 SetOutValue
- 3.11 ReadSignalStrengthFromScan
- 3.12 ReadEncryptionModeFromScan
- 3.13 GetByteWithTimeout
- 3.14 GetInValue
- 3.15 ConnectToSSID
- 3.16 ScanForSSID
- 3.17 Initialise
- 3.18 CheckTCPServerIP
- 4 Simulation macro reference
- 5 Property reference
Wireless LAN component designed to work with the ESP-12S module. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the BL0136 WIFI E-block.
This component can be used for connecting a system to a wifi network, by using the ‘ScanForSSID’ component macro. Then different macros can be used to read the encryption mode, the signal strength or the specific SSID of one of the networks picked up in the scan. There is also a ‘ConnectToSSID’ macro which allows you to connect your program to a wifi network (as long as you have a sufficient password) and another macro you can use to disconnect from the network again. As well as connecting to a wifi network, there is a component macro called ‘CreateAccessPoint’ which creates an access point (with a chosen SSID, password, channel, and encryption) for other people to connect to.
DisconnectFromSSID
Disconnects from the current SSID.
Returns 1 if the command was accepted and returned an "OK"
SendString
Sends the given Text.
Appends a CR to the end of the string it SendCR is greater than 0.
- <- STRING Text
- BYTE SendCR
ClientConnect
Creates a TCP or UDP connection to a remote server.
Returns the state of the connection.
0=Connection failed
1=Connection active
- BYTE Type
- 0 = TCP, 1 = UDP
- <- STRING IPAddress
- e.g. "192.168.1.20"
- UINT Port
- Remote port number to connect to, HTTP comms = Port 80
ControlTCPServer
Allows a TCP web page server to be switched on and off on the selected port.
Returns 1 if the command was completed correctly.
- BYTE Enable
- 0 = Stop Server, 1 = Start Server
- UINT Port
- Server port to listen for incoming TCP/IP data requests
GetFirmwareVersion
Collects the firmware version from the ESP8266 module and returns it as a string.
ClientSendRequest
Sends out a request for data
- <- STRING Request
- e.g. "GET / HTTP/1.0\r\n\r\n"
ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan.
The ScanForSSID macro must be called first.
- BYTE Index
- SSID Index
CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network.
Other WIFI enabled devices can then connect to the module.
Returns 1 for success.
- <- STRING SSID
- Name of the wireless network to create
- <- STRING Password
- Password used to gain access to the network
- BYTE Channel
- 802.11 Channel Range 1-14
- BYTE Encryption
- 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
SetOutValue
- BYTE index
- Range 0-4
- <- STRING value
Collects the signal strength from the last SSID Scan.
Value returned is in negative dB, smaller value = better signal
- BYTE Index
- SSID Index
Collects one of the encryption modes from the last SSID Scan.
- BYTE Index
- SSID Index
GetByteWithTimeout
Attempts to receive a byte from the circular buffer.
If nothing is available then waits up to 20 ms for data to become available.
GetInValue
- BYTE index
- Index of the request paramter, starting at zero Range 0-2
ConnectToSSID
Attempts to connect to the given SSID and Key values.
Returns 1 if the SSID has been connected.
- <- STRING SSID
- <- STRING Key
- BYTE Timeout
- Number of seconds to wait for the connection, default 2
ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID.
Must not be connected to a network to allow this to function.
Returns the number of wireless networks found, max 8.
Initialise the device with the property data.
Returns 1 if "ready" message successfully received
Returns 0 if no reply from module
CheckTCPServerIP
Collects the local IP address of the active TCP server.
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name RxBufferSize.
Buffer used to store incoming data ready for processing.
Default 128 Bytes.
Scan Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ScanBufferSize.
Buffer used to hold SSID names when performing a SSID network scan.
Default 100 Bytes.
Reset Mode
This property is of type Fixed list of ints and can be referenced with the variable name ResetMode.
The initialise automatically resets the WIFI module before establishing communications.
Software reset uses an AT command to preform the reset
Hardware reset uses an extra I/O pin to toggle the signal to the reset pin on the module.
Command Termination
This property is of type Fixed list of ints and can be referenced with the variable name Termination.
Older versions of the firmware require \r to terminate a AT command string.
Newer versions of the firmware have changed to use \r\n termination.
This property is of type Fixed list of ints and can be referenced with the variable name group1::cal_uart1::CHANNEL.
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name group1::cal_uart1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name group1::cal_uart1::BAUD.
TX
This property is of type Single digital pin and can be referenced with the variable name group1::cal_uart1::TX.
TX Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name group1::cal_uart1::OutputPins.
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
This property is of type Single digital pin and can be referenced with the variable name group1::cal_uart1::RX.
RX Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name group1::cal_uart1::InputPins.
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Reset
This property is of type Single digital pin and can be referenced with the variable name RESET.
WLAN module reset pin connection
Use Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name group1::cal_uart1::FLOWEN.
Flow Control (Handshake) enable or disable.
On: Two I/O pins are used to control the flow of data in and out of the device.
Off: Flow control is disabled.
Max Web Pages
This property is of type Fixed list of ints and can be referenced with the variable name PAGES.
Maximum number of individual webpages we can serve up with the component.
Web Page Timeout
This property is of type Unsigned integer and can be referenced with the variable name TIMEOUT.
Number of cycles to try and send / receive a webpage before timing out.
Line Delay
This property is of type Unsigned integer and can be referenced with the variable name LineDelay.
Fixed delay in microseconds sent in between sending a HTML line when running as a web page server.
Name Page 1
This property is of type Line of text and can be referenced with the variable name name1.
HTML name of webpage 1
HTML Page 1
This property is of type Multiple lines of text and can be referenced with the variable name html1.
HTML content for webpage 1
Name Page 2
This property is of type Line of text and can be referenced with the variable name name2.
HTML name of webpage 2
HTML Page 2
This property is of type Multiple lines of text and can be referenced with the variable name html2.
HTML content for webpage 2
Name Page 3
This property is of type Line of text and can be referenced with the variable name name3.
HTML name of webpage 3
HTML Page 3
This property is of type Multiple lines of text and can be referenced with the variable name html3.
HTML content for webpage 3
Name Page 4
This property is of type Line of text and can be referenced with the variable name name4.
HTML name of webpage 4
HTML Page 4
This property is of type Multiple lines of text and can be referenced with the variable name html4.
HTML content for webpage 4
Count
This property is of type Fixed list of ints and can be referenced with the variable name Outgoing_Count.
Length 0
This property is of type Unsigned integer and can be referenced with the variable name Out_Len_0.
Count
This property is of type Fixed list of ints and can be referenced with the variable name Incoming_Count.
Length 0
This property is of type Unsigned integer and can be referenced with the variable name In_Len_0.
Simulation Method
This property is of type Fixed list of ints and can be referenced with the variable name SimMethod.
Decides how to handle the simulation of the component.
TCP Base - Allows simulation of the network communications using the TCP Base component and DLL.
COM/Injector - Allows the simulation to connect to real hardware or injectors.
This property is of type True or false and can be referenced with the variable name group1::cal_uart1::ScopeTraces.
Selects if the scope traces are automatically added to the data recorder window or not.
Simulation - draws an approximation of the UART data onto the scope trace.
ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
This property is of type True or false and can be referenced with the variable name group1::cal_uart1::ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name group1::cal_uart1::ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name group1::cal_uart1::DataSource.
Simulation data source used to allow the component to connect to various remote devices
Nothing - Simulation data is ignored
COM port - Routes the communication data to and from a physical or virtual COM port
Injector - Routes the communication data via a data injector component on the Panel.
