Component: Potentiometer (EBM002) (EBM Modules)
| Version | 1.1 |
| Category | EBM Modules |
Potentiometer component
This board consists of a standard shaft rotary potentiometer that provides a linear voltage output ranging between the microcontroller power rails. This can be connected to an Analogue to Digital input of the microcontroller in order to provide a control value.
This example simply reads the value from the potentiometer sensor component and outputs the value to an LCD as a number in the range 0-255.
The ADC bit depth can be increased to 10 or 12 bit depending on your device by changing the Mode parameter to 1 in the ReadPotentiometer component macro.
| ReadPotentiometer | |
| Macro to read the potentiometer Mode = 0 will return a byte Mode = 1 will return an int | |
| [[File:]] - | Mode |
| 0 = return BYTE, 1 = return INT | |
| [[File:]] - | Return |
| GetTempString | |
| Gets the temperature returned by calling SampleSensor as a string. If temperature is 15.8 degrees C then this function would return "15.8". | |
| GetHumidityString | |
| Gets the humidity returned by calling SampleSensor as a string. If humidity is 15.8 % then this function would return "15.8". | |
| GetHumidityWhole | |
| Gets the whole number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 15. | |
| GetTempReal | |
| Gets the real number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 8. | |
| GetHumidityReal | |
| Gets the real number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 8. | |
| SampleSensor | |
| Communicates with the DHT22 sensor and receives the temperature and humidity readings. Returns 0 for success, 1 for no communication detected and 2 for checksum error. | |
| GetTempFloat | |
| Gets the temperature returned by calling SampleSensor as a floating point number. If temperature is 15.8 degrees C then this function would return 15.8. | |
| Initialise the sensor configuration as set by the component properties | |
| Stes up the I2C bus and initialises the termperature sensor ready for use. | |
| SimSetGyro | |
| Allows the XYZ slider values to be set via the simulation | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| UpdateAccelerometerData | |
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
| SimSetCompass | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| [[File:]] - | State |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
| SPIInitialise | |
| Channel | |
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0 - 11 | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-11 | |
