Component: Touch Pads (EBM013) (EBM Modules)
Revision as of 20:45, 16 November 2021 by Wiki bot (talk | contribs)
Category EBM Modules
Touch Pads component
This board provides two touch areas for use with capacitive sensing. Hence two digital touch switches can be implemented. This component directly interfaces with the EBM013 Sensors board.
Sample program using the EBM013 - Touch Pads sensor.
Sensors are first calibrated and then can be read as digital switches
EBM013 Example
GetTouchValue
Samples the touch sensor ADC value and returns it Always samples both channels, but only returns the chosen channel
[[File:]] - Switch
Select Switch. Switch 1 = 0, Switch 2 = 1
GetTouchPressed
Returns non-zero if touch detected
[[File:]] - Switch
- UINT OffValue
- BYTE Threshold
Provide the threshold value for the pad to be considered touched
[[File:]] - Return
WriteRegister
Writes the data byte to the given address of the device. Returns 0 if successful
- BYTE Reg
address of register to be written with data byte
- BYTE data
data byte to be written to device register
Initialise the component. Returns 0 if successful
Set up the thermocouple sensor ready for use.
Initialise the sensor configuration as set by the component properties
Stes up the I2C bus and initialises the termperature sensor ready for use.
SimSetGyro
Allows the XYZ slider values to be set via the simulation
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
SimSetCompass
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE NumSamples
The number of readings to base the bearing on
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
IOSetOutputPin
- BYTE Pin
Range: 0-29
[[File:]] - State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE Channel
SPIInitialise
- BYTE Channel
OneWireReceiveByte
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
OneWireGetDeviceCount
- BYTE Channel
PWMSetPrescaler
- BYTE Channel
Range: 0 - 11
- BYTE Prescaler
- BYTE Period
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-11
ADCSampleArray10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
Channel 1
ADC Channel number
Channel 2
On Value
Off Value
On Value
Off Value
Simulations
