App Developer Examples
Revision as of 17:38, 27 November 2018 by BenR (talk | contribs)
AllCode Examples
Formula AllCode
A simple example showing how to drive the Formula AllCode robot around in API mode using a panel based joystick control.
Formula AllCode Bluetooth
The COM port for the Formula AllCode can be set via the panel properties which can be exposed to the SCADA runtime user.
MIAC AllCode
A simple example showing how to drive the MIAC AllCode PLC from a SCADA application using Bluetooth or WIFI.
MIAC AllCode
Arduino Examples
Arduino Uno Slave
A simple example demonstrating how to use an Arduino with Flowcode SCADA.
Firstly we have an embedded project targetting an Arduino Uno that is connected to a bank of LEDs, a bank of switches and a temperature/humidity sensor.
ArduinoUnoFW
Secondly we have a SCADA project that can interrogate and control the Arduino Uno allowing access to the switches, termperature and humidity while also allowing the LEDs to be controlled.
ArduinoUnoSCADA
Internet Based Examples
Local Weather
A simple example demonstrating how to use MQTT with Flowcode SCADA to get the local weather conditions.
The example shows temperatures from Halifax in the UK and from Sydney in Australia.
SCADA BBC TEMPERATURES
MQTT
Modbus TCP
A simple example demonstrating how to use the Modbus TCP components with Flowcode SCADA.
Here we have two Flowcoded SCADA projects communicting with each other. Though the master or slave could be replaced with embedded Modbus TCP hardware.
Modbus TCP Master
Modbus TCP Slave
Webserver Embedded Files
Webserver Dynamic Files
==Generic Examples
Industrial Tanks
Key Mappings
