Component: DAC (Internal) (Analog Output)
Revision as of 16:14, 16 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Analog Output
DAC (Internal) component
Provides access to the onboard digital to analog converter (DAC) peripheral allowing for simple analogue output. Often the DAC output will be very low current and will need amplification using external circuitry to drive anything useful.
SetOutput
Sets the output voltage of the DAC
- UINT DAC_Value
The value to output to the DAC
GetValue
Gets the Name property value
- STRING Name
The name of the property
- STRING Return
Disable
Disables the DAC output.
Enable
Enables the DAC Output.
SetValue
Sets the Value for the named property
- STRING Name
Name of property to update
- STRING Value
The new value for the property
GetList
- STRING Name
- STRING Return
SetPivotPos
Sets the position of the object the lever rotates around
[[File:]] - PositionHandle
A handle to the position of the depressed location
SetAutoReset
Sets the state of the auto-reset flag If the flag is true (it is by default) then Button Helper will reset the state of each button on stop
[[File:]] - State
Set true to reset to off on sim stop, else false to retain state
SetLatching
Sets whether the button is depressed when the mouse is released
[[File:]] - Enabled
Unregister
Removes the object to the list if present
[[File:]] - Target
SetMovementFor
Sets the movement in units or PI/16 steps for the button
[[File:]] - Target
[[File:]] - Move
Movement to set to, default 4
GetList
Gets Named property List
- STRING Name
- STRING Return
GetList
returns Named property list
- STRING Name
- STRING Return
DAC Channel number
DAC Output Pin
DAC Output Pin
Vref Option
Vref Voltage
Control Bits
Resolution
Voltage Resolution
Simulations
