Component: Hopper (Industrial)
| Category | Industrial |
Hopper component
A simple hopper that can be used to store produce. The hopper has component macros to set and get the current level of produce. The hopper can be initialised to be full or empty when starting. Compatible with SCADA interconnecting pipe components.
SCADA
Industrial Tanks
A simple example showing the hoppers, valves and pipes working together. Each tank automatically empties in turn.
| AdjustLevel | |
| Allows the lelev in the hopper to be adjusted up or down. | |
| Adjustment | |
| GetLevel | |
| Returns the current amount of produce in the hopper. | |
| IsFull | |
| Check to see if the hopper is currently full. Returns 0 if not full or 1 if full. | |
| IsEmpty | |
| Check to see if the hopper is currently empty. Returns 0 if not empty or 1 if empty. | |
| SetLevel | |
| Sets the current amount of produce in the hopper. | |
| Level | |
| The amount of produce in the hopper. | |
