Component: IntOsc Helper (Matrix Tools)
Revision as of 16:14, 16 November 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Matrix Tools
IntOsc Helper component
A component to help configure the speed of the internal oscillator. Currently only supports 8-bit PIC devices.
The INT OSC helper component is designed to help you configure the rate of the internal oscillator on-board your microcontroller.
It can be found under the Runtime -> Matrix Tools component category.
The oscillator speed drop down menu shows you what speeds are available on your device. Use this to select a speed.
Once you have chosen your required internal oscillator speed copy the code from the Code property.
Paste the configuration code into a C icon at the top of your main macro.
Next change the clock speed in the project options to match your oscillator speed. This will ensure that delays and baud rates are calculated correctly.
Finally you need to enable the internal oscillator in the configuration settings.
If everything is correct then the Info field should confirm that the project options clock speed matches the current speed selection.
Called to set the internal oscillator speed to the specified value.
CheckBuffer
Returns the number of values in the transmit or receive buffer
[[File:]] - Buffer
0=Transmit / 1=Receive
ReceiveString
Gets a string from the receive buffer
- UINT MaxChars
- UINT Timeout
Time in milliseconds to wait for data
- STRING Return
Initialises the UART component pins ready to send and receive data
ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
- BYTE Data
A byte array variable to hold the received data
- UINT NumBytes
Maximum number of bytes to try and receive
- UINT Timeout
Max amount of time in ms to wait between bytes
ReceiveString
Receives a string of bytes and returns the number of bytes received.
- STRING StringData
- UINT NumBytes
- UINT Timeout
Uninit
Un-initialize the UART and release the resources
GetList
Gets Named property List
- STRING Name
- STRING Return
Delay
Software UART Bit Delay
SetValue
set Value of Named property
- STRING Name
- STRING Value
Uninit
GetList
- STRING Name
- STRING Return
ReceiveByteArray
- BYTE Data
- BYTE NumBytes
- BYTE Timeout
ReceiveString
- STRING StringData
- BYTE NumBytes
- BYTE Timeout
GetList
returns Named property list
- STRING Name
- STRING Return
Oscillator Speed
Shows what internal oscillator speeds are available on the device and allows the user to select an option.
Info
General info to the user, checks to see if the selected oscillator speed matches the project oscillator speed.
Code
Code to configure the internal oscillator module. This code must be added to a C icon which should be placed at the top of main.
Simulations
