Component: Console Writer (Indicators)
Version 1.0 (Release)
Category Indicators
Image Console Writer component
A simple component to aid in creating and wiriting data to a console tab. Allows text to be coloured and automatically appended with a timestamp.
This component does not contain any downloadable macros
Simulation macro reference
Clear
Clears the contents of the console tab.
This macro has no parameters
CountLines
Counts the number of lines in the console.
ULONG
AddString
Adds text string to the console window.
<- STRING Data
This parameter may be returned back to the caller
SetTextLine
Sets the string data from a specific line in the console.
LONG Line
Line number, -1 for the last line.
<- STRING Data
SetColour
Allows for full RGB colour selection
BYTE R
Colour channel, Range: 0-255
BYTE G
BYTE B
SetColourIdx
Sets the text colour from the properties selection of colours.
BYTE Index
Range: 0-3
GetTextLine
Gets the string data from a specific line in the console.
LONG Line
STRING
Console Name
This property is of type Line of text and can be referenced with the variable name ConsoleName.
Textual name of the console shown as the tab name at the top of the console window.
Colour 0
This property is of type Color picker and can be referenced with the variable name Colour0.
Used to define a colour channel referenced by the SetColourIdx component macro call.
Colour 1
This property is of type Color picker and can be referenced with the variable name Colour1.
Colour 2
This property is of type Color picker and can be referenced with the variable name Colour2.
Colour 3
This property is of type Color picker and can be referenced with the variable name Colour3.
New Line After Data
This property is of type True or false and can be referenced with the variable name NLAfterData.
Automatically append a newline character after any data has been written to the console using the AddString component macro.
Clear On Sim Start
This property is of type True or false and can be referenced with the variable name ClearOnSimStart.
Automatically clear the console tab when the simulation is started.
Add Timestamp
This property is of type True or false and can be referenced with the variable name Timestamp.
Automatically adds a timestamp to the console after a newline character has been received.
Date Format
This property is of type Fixed list of ints and can be referenced with the variable name TimeStamp1::DateFormat.
Specifies the format of the date string.
No - "DD/MM/YY"
Yes - "MM/DD/YY"
Time Separator
This property is of type Line of text and can be referenced with the variable name TimeStamp1::TimeSeperator.
Characters that are used in between the time digits
Date Separator
This property is of type Line of text and can be referenced with the variable name TimeStamp1::DateSeparator.
Characters that are used in between the date digits
TimeStamp Separator
This property is of type Line of text and can be referenced with the variable name TimeStamp1::TimeStampSeparator.
Characters that are used between the time and date strings when returning a full time stamp.
Override Colour
This property is of type True or false and can be referenced with the variable name OverrideColour.
Overrides the current selected colour when writing the timestamp.
Timestamp Colour
This property is of type Color picker and can be referenced with the variable name TimestampColour.
Defines the colour of the time stamp text.
