Bot test
Revision as of 12:48, 12 August 2021 by DavidA (talk | contribs)
Command Buffer Size
Maximum number of bytes that can be stored in the outgoing command buffer.
Response Buffer Size
Maximum number of bytes that can be stored in the incoming response buffer.
Script Count
Controls how many AT scripts are stored into non-volatile memory
Script 1
Data to send for script 0, each command should be terminated with a carriage return
TX
RX
Use Flow Control
Baud Options
Simulations
Console Columns
Data Source
API
Selects whichAPI component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
