Bot test
Revision as of 13:32, 17 August 2021 by DavidA (talk | contribs)
StringRead
Returns the ASCII value of character idx of the Response string.
- BYTE idx
Needs to be a equal to or less than the string length of the response in order to retrieve a valid character.
SendScript
Sends Script idx Note that the general property Number of Scripts needs to be set so that it allows the scripts to be accessed and sent. Returns 0 for success and 1 for error
- BYTE idx
Refers to the Script page to send (1-4).
SendCommand
Sends the command buffer. Returns 1 for success in sending the command. Returns 0 for errors.
- BYTE ExpectEcho
Remote module automatically echos back data: 1 = On (Expect echo), 0 = off
- BYTE SendCR
Automatically adds \n to the end of the command data: 1 = append CR, 0 = no CR.
CreateCommandString
Assigns a string of characters to the Command buffer. Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
- STRING Data
- BYTE SendCR
StringReceive
Checks for a response string. Returns the length of the response string if one is present otherwise returns 0.
- STRING Data
- BYTE SendCR
CreateCommand
Adds a single characters to the end of the Command buffer. Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
- BYTE Character
ASCII value or single character,
[[File:]] - Elements
The number of elements in the array
Send_byte
- BYTE ByteVal
WaitForResponse
Waits for a response message of type response_code for timeout ms. Returns: 0 for a Response of type response_code 255 (0xFF) for a timeout or invalid response Response string length for any Response not of type response_code
- BYTE response_code
1:OK / 2:ERROR / 3:CONNECT / 4:NO CARRIER / 5:AUDIO / 6:PAIR / 7:RING
- BYTE timeout
The timeout value will need to set to allow sufficient time for the response to arrive.
Required to be used whenever the Bluetooth component is used in a program. Initialises the Bluetooth component ready for use.
- BYTE timeout
