Bot test
Revision as of 13:35, 17 August 2021 by DavidA (talk | contribs) (Undo revision 24875 by DavidA (talk))
ev_Prop_Change
- ULONG Return
StringRead
Returns the ASCII value of character idx of the Response string.
- BYTE idx
Needs to be a equal to or less than the string length of the response in order to retrieve a valid character.
Ev_Timer
Called back on the panel command System.TimerStart
- ULONG TimerID
The identifier passed to the System.TimerStart panel command
- ULONG Return
SendScript
Sends Script idx Note that the general property Number of Scripts needs to be set so that it allows the scripts to be accessed and sent. Returns 0 for success and 1 for error
- BYTE idx
Refers to the Script page to send (1-4).
SendCommand
Sends the command buffer. Returns 1 for success in sending the command. Returns 0 for errors.
- BYTE ExpectEcho
Remote module automatically echos back data: 1 = On (Expect echo), 0 = off
- BYTE SendCR
Automatically adds \n to the end of the command data: 1 = append CR, 0 = no CR.
SendScriptString
- STRING str
- BYTE SendCR
Ev_ChipChange
Sent when the target device has changed
[[File:]] - Target
The name of the new target device
- BYTE SendCR
- ULONG Return
Read_byte
- BYTE Timeout
- BYTE SendCR
CreateCommandString
Assigns a string of characters to the Command buffer. Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
- STRING Data
- BYTE SendCR
ev_Init
- STRING Data
- BYTE SendCR
- ULONG Return
StringReceive
Checks for a response string. Returns the length of the response string if one is present otherwise returns 0.
- STRING Data
- BYTE SendCR
Ev_GetVarSize
Sent to a component to amend the size of the expected array
[[File:]] - VarName
The original Flowcode variable
[[File:]] - Elements
The number of elements in the array
- ULONG Return
CreateCommand
Adds a single characters to the end of the Command buffer. Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
- BYTE Character
ASCII value or single character,
Send_byte
- BYTE ByteVal
WaitForResponse
Waits for a response message of type response_code for timeout ms. Returns: 0 for a Response of type response_code 255 (0xFF) for a timeout or invalid response Response string length for any Response not of type response_code
- BYTE response_code
1:OK / 2:ERROR / 3:CONNECT / 4:NO CARRIER / 5:AUDIO / 6:PAIR / 7:RING
- BYTE timeout
The timeout value will need to set to allow sufficient time for the response to arrive.
Main
- BYTE timeout
pvt_Scripts_ShowHide
- BYTE timeout
Required to be used whenever the Bluetooth component is used in a program. Initialises the Bluetooth component ready for use.
- BYTE timeout
