API Scope.AddOp
<sidebar>API contents</sidebar> Adds an operation to act on the inputs of the stream
HANDLE StreamH
- A handle to a previously created datascope stream
ULONG FuncOp
- An operation to perform on the input
Typical values for this parameter:
| Type | Name | Description |
| LONG | Op_Bound | Bound the current value to the expected range of the input |
| LONG | Op_Scale | Divide the current value to the expected range of the input |
| LONG | Op_Xor | Exclusive-or with the provided integer argument |
| LONG | Op_AndNot | Clear the bits in the provided integer argument |
| LONG | Op_And | Isolate only the bits in the provided integer argument |
| LONG | Op_Orr | Set the bits in the provided integer argument |
| LONG | Op_Not | Invert (ones-compliment) the current input |
| LONG | Op_Add | Add the argument to the current input |
| LONG | Op_Sub | Subtract the argument from the current input |
| LONG | Op_Mul | Multiply the argument by the current input |
| LONG | Op_Div | Divide the current input by the argument |
| LONG | Op_Pow | Raise the input to the power of the argument |
| LONG | Op_Neg | Negate (twos compliment) the current input |
| LONG | Op_Recip | Perform the reciprocal on the current input |
| LONG | Op_Sqrt | Perform a square root on the current input |
| LONG | Op_Ln | Perform a natural logarithm on the current input |
| LONG | Op_Ln2 | Perform a base-2 logarithm on the current input |
| LONG | Op_Cos | Convert the input to its cosine value (input is in radians) |
| LONG | Op_Sin | Convert the input to its sine value (input is in radians) |
| LONG | Op_Tan | Convert the input to its tangent value (input is in radians) |
| LONG | Op_Int | Convert the input from a float to an integer (using the floor function) |
FLOAT Arg
- An optional argument that may be used by the FuncOp
- Add to a calculation icon:
result = ::Scope.AddOp(streamh, ::Scope.Op_Bound, arg)
