Component: DSPBufferRef (DSP)
Revision as of 10:35, 17 November 2021 by Wiki bot (talk | contribs)
Category DSP
DSPBufferRef component
Reference and access to a specific DSP buffer inside another DSP component. Used for a DSP component input buffer.
Prv_PutPropStr
- UINT Idx
- UINT Val
Prv_PutConsole
- UINT Idx
- ULONG Val
get
- UINT Idx
[[File:]] - Return
put
- UINT Idx
[[File:]] - Val
Prv_GetPropStr
- UINT Idx
Prv_GetConsole
- UINT Idx
- ULONG Return
SetHandle
[[File:]] - Handle
Uninit
Un-initialize the UART and release the resources
ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
- BYTE Data
A byte array variable to hold the received data
- UINT NumBytes
Maximum number of bytes to try and receive
- UINT Timeout
Max amount of time in ms to wait between bytes
ReceiveString
Receives a string of bytes and returns the number of bytes received.
- STRING StringData
- UINT NumBytes
- UINT Timeout
Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
SetLEDState
Sets the state of a single LED
- BYTE Port
0 = PortA, 1 = PortB
- BYTE LED
0 = LED0, 7 = LED7
- BYTE State
GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
- BYTE Buffer
- ULONG Return
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Link To
Subname
Subhandle
Buffer Size
Buffer Type
Console Handle
Color
Outline
Text
Orientation
Simulations
