Component: Temperature Infrared (Grove 101020062) (Environmental)
Revision as of 10:39, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category Environmental
Temperature Infrared component
The Grove Infrared Temperature Sensor allows none contact measurement of temperatures ranging from -10 to 100 degrees C.
MeasureSurTemp
Measures the surrounding ambient temperature,
[[File:]] - Return
MeasureObjectTemp
Measures the temperature of the targetted object
[[File:]] - Return
GetADCValue
Gets the raw ADC input value for the IR receiver
Initialise the component by loading the default calibration table
Initialise the sensor configuration as set by the component properties
Initialises the component ready for I2C communications
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
SimSetGyro
Allows the XYZ slider values to be set via the simulation
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
SimSetCompass
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE NumSamples
The number of readings to base the bearing on
IOSetOutputPin
- BYTE Pin
Range: 0-29
[[File:]] - State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE Channel
SPIInitialise
- BYTE Channel
OneWireReceiveByte
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
OneWireGetDeviceCount
- BYTE Channel
PWMSetPrescaler
- BYTE Channel
Range: 0 - 11
- BYTE Prescaler
- BYTE Period
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-11
ADCSampleArray10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Ambient Pin (SUR)
Object Pin (OBJ)
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Temperature Calibration
Ambient temperature calibration value
Temperature Range
Map of temperature-voltage according to sensor datasheet. 10 is the temperature step when sensor and object distance is 9CM.
Offset Voltage
Voltage of mid level voltage after 5-10 mins to bring the sensor to ambient.
Number of Samples
Number of samples to take to average out each reading. Default 10.
Simulations
