Author
Matrix TSL
Version
1.0
Category
Environmental
Barometer (DPS310) component
A barometric air pressure sensor with high accuracy and low current consumption. Capable of sensing air pressure and temperature. Based on an I2C bus connection.
ReadTemperature
Reads the temperature measurement from the last SampleSensor macro
[[File:]] -
ConfigurePressure
Configures the pressure sensor sample rate and over sampling count
- BYTE
Rate
Range: 0-7, 0=1Hz, 1=2Hz, 2=4Hz etc
- BYTE
Oversample
Range: 0-7, 0=1Samples, 1=2Samples, 2=4Samples etc
ConfigureTemperature
Configures the temperature sensor sample rate and over sampling count
- BYTE
Rate
- BYTE
Oversample
ReadPressure
Reads the pressure measurement from the last SampleSensor macro
[[File:]] -
SetMode
Sets the operational mode of the sensor to be continous or one shot
- BYTE
Mode
ReadAltitude
Reads the pressure measurement from the last SampleSensor macro and converts the pressure reading into an altitude reading.
[[File:]] -
SampleSensor
Checks to see if new data is available for temperature or pressure and collects it. Returns 0 if no new data is available Returns 1 for pressure, 2 for temperature and 3 for both.
- BYTE
ReadRegister
Reads a byte from a register
- BYTE
Address
- BYTE
WriteRegister
Writes a byte to a register
- BYTE
Address
- BYTE
Data
Starts up the I2C ready to communicate with the sensor. Sets the selected rates and operational mode. Returns 1 if the sensor has been found and initialised.
[[File:]] -
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
SimSetCompass
Allows the XYZ slider values to be set via the simulation
[[File:]] -
X
[[File:]] -
Y
[[File:]] -
Z
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE
NumSamples
The number of readings to base the bearing on
- UINT
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
- BYTE
IOSetOutputPin
- BYTE
Pin
Range: 0-29
[[File:]] -
State
Range: 0-1
UARTReceive
- BYTE
- BYTE
ADCSampleAverage10
- BYTE
ADCChannel
Range: 0, 3-7
- BYTE
SampleCount
Range: 1- 100
- BYTE
SampleDelay
- UINT
OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE
- BYTE
SPIInitialise
- BYTE
OneWireReceiveByte
- BYTE
- BYTE
I2CSend
- BYTE
- BYTE
DataOut
[[File:]] -
UARTSend
- BYTE
- BYTE
Data
OneWireGetDeviceCount
- BYTE
- BYTE
PWMSetPrescaler
- BYTE
Range: 0 - 11
- BYTE
Prescaler
- BYTE
Period
PWMEnable
Enable a PWM output
- BYTE
Range: 0-11
ADCSampleArray10
- BYTE
ADCChannel
Range: 0, 3-7
- BYTE
SampleCount
Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE
ADCChannel
Range: 0, 3-7
- BYTE
SampleCount
Range: 1- 100
- BYTE
SampleDelay
- BYTE
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
Range 0-63 or 0b00000 to 0b111111
Device Address
Measurement Rate
Oversample Rate
Operational Mode
API
Specifies the API component on the panel to interact with to provide comms simulation.
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Simulations
Simulate Comms
No: Provides simulation using the panel component sliders. Yes: Communicates via an API Slave device to real world hardware, shows the results using the panel component sliders.
