Component: Barometer (MS5637) (Environmental)
| Category | Environmental |
Barometer component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 0 to 30 Bar. Temperature range -20 to +85 °C.
| Reset | |
| Resets the device | |
| ReadPROM | |
| Reads a single 16-bit value from the PROM calibration data. | |
| Address | |
| Range 0-6 | |
| Stes up the I2C bus and initialises the termperature sensor ready for use. | |
| ReadRegister | |
| Reads a byte from a register | |
| Address | |
| WriteRegister | |
| Writes a byte to a register | |
| Address | |
| Data | |
| Starts up the I2C ready to communicate with the sensor. Sets the selected rates and operational mode. Returns 1 if the sensor has been found and initialised. | |
| [[File:]] - | Return |
| UpdateAccelerometerData | |
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
| SimSetCompass | |
| Allows the XYZ slider values to be set via the simulation | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| [[File:]] - | State |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
| SPIInitialise | |
| Channel | |
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0 - 11 | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-11 | |
