Component: Joystick (Sparkfun Quiic) (Analog Input)
Revision as of 10:39, 17 November 2021 by Wiki bot (talk | contribs)
Category Analog Input
Joystick (Sparkfun Quiic) component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
Traffic Light Scenario
ChangeI2CAddress
Allows the I2C Device address to be changed which in turn allows more then one RFID reader to sit on the same physical I2C bus. Returns 1 if succesful.
- BYTE NewAddress
Range: 8 to 119 or 0x08 - 0x77
[[File:]] - Return
CheckButton
Checks to see if the button has been pressed since the last read of CheckButton or ReadButton.
[[File:]] - Return
ReadAxis
Reads a single axis of the joystick and returns as a signed integer value.
- BYTE Axis
Range 0-1 Where 0=X, 1=Y
[[File:]] - Type
0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023)
[[File:]] - Return
ReadButton
Checks to see if the button is currently pressed
[[File:]] - Return
Initialises the I2C bus ready for communications with the module.
OpenPort
Opens the currently selected COM port, allowing data to be sent and received.
SetProp
Allows the COM port property to be set from a parent component.
- STRING PropName
- ULONG PropVal
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING PropName
- STRING Return
GetConsoleHandle
[[File:]] - Return
SendByteArray
Sends an array of bytes to the COM port.
- BYTE Data
Data byte array to send
- UINT Length
Number of bytes to send
ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
[[File:]] - MSBfirst
0=Least significant byte first, 1=Most significant byte first
- BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE Timeout
Max time in ms to wait in between bytes
[[File:]] - IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
[[File:]] - Return
SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
[[File:]] - Number
SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG Number
- BYTE NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
[[File:]] - Prefix
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SetFlowControl
Allows the Flowcontrol signals to be enabled or disabled.
- BYTE State
A value of 0 disables flow control, 1 or above willl enable flow control.
OpenPort
ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE Timeout
[[File:]] - Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG Return
SetProp
- STRING PropName
- ULONG PropVal
SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
- ULONG Value
SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
[[File:]] - Value
GetProp
- STRING PropName
- STRING Return
ReceiveByteArray
Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE Data
- UINT MaxLength
Max number of bytes to try and read
- UINT Timeout
Time to wait for incoming data in milliseconds
ReceiveString
Attempts to receive an string using the COM port Returns the number of bytes received.
- UINT Timeout
- UINT MaxLength
- STRING Return
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
GetProp
- STRING PropName
- STRING Return
Return To Center
Decides if the joystick automatically returns to the center position when released. Yes: The joystick will return to the center when released. No: The joystick will remain in the current position when released.
X Min
X Max
Y Min
Y Max
Device Address
External device address used to communicate with the module. Default 32 or 0x20
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Simulations
Simulate Comms
Controls if we are using the panel simulation or simulating the I2C calls for use with an I2C injector.
API
