| Author
Matrix Ltd
| Version
1.0
| Category
Third Party
FTDI (FTD2XX) component
Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system. For more details refer to the D2XX_Programmers_Guide from FTDI.
FT_GetStatus
| Gets the device status including number of characters in the receive queue, number of characters in the transmit queue, and the current event status.
| [[File:]] -
Handle
| Handle of the device.
| [[File:]] -
RxQueueLength
| Pointer to a variable of type DWORD which receives the number of characters in the receive queue.
| [[File:]] -
TxQueueLength
| Pointer to a variable of type DWORD which receives the number of characters in the transmit queue.
| [[File:]] -
EventStatus
| Pointer to a variable of type DWORD which receives the current state of the event status.
- BYTE
FT_ClrRts
| This function clears the Request To Send (RTS) control signal.
| [[File:]] -
Handle
FT_Write
| Write data to the device.
| [[File:]] -
Handle
- BYTE
Buffer
| Pointer to the buffer that contains the data to be written to the device.
- ULONG
Bytes
| Number of bytes to write to the device.
- ULONG
Count
| Pointer to a variable of type DWORD which receives the number of bytes written to the device.
- BYTE
FT_Read
| Read data from the device.
| [[File:]] -
Handle
- BYTE
Buffer
| Pointer to the buffer that receives the data from the device.
- ULONG
Bytes
| Number of bytes to be read from the device.
- ULONG
Count
| Pointer to a variable of type DWORD which receives the number of bytes read from the device.
- BYTE
FT_SetFlowControl
| This function sets the flow control for the device.
| [[File:]] -
Handle
- UINT
FlowControl
| Flow setting 0=None, 0x0100=RTS/CTS, 0x0200=DTR/DSR, 0x0400=XON/XOFF
- BYTE
Xon
| Character used to signal Xon. Only used if flow control is Xon/Xoff
- BYTE
Xoff
| Character used to signal Xoff. Only used if flow control is Xon/Xoff
- BYTE
FT_GetModemStatus
| Gets the modem status and line status from the device.
| [[File:]] -
Handle
| [[File:]] -
ModemStatus
| Pointer to a variable of type DWORD which receives the modem status and line status from the device.
- BYTE
FT_SetBreakOn
| Sets the BREAK condition for the device.
| [[File:]] -
Handle
- BYTE
FT_CreateDeviceInfoList
| This function builds a device information list and returns the number of D2XX devices connected to the system. The list contains information about both unopen and open devices.
| [[File:]] -
DevCount
| Unsigned long array used to store the number of devices connected
- BYTE
FT_SetTimeouts
| This function sets the read and write timeouts for the device.
| [[File:]] -
Handle
| [[File:]] -
ReadTimeout
| Read timeout in milliseconds.
| [[File:]] -
WriteTimeout
| Write timeout in milliseconds.
- BYTE
FT_SetBitMode
| Enables different chip modes.
| [[File:]] -
Handle
- BYTE
Mask
| Required value for bit mode mask. This sets up which bits are inputs and outputs. A bit value of 0 sets the corresponding pin to an input, a bit value of 1 sets the corresponding pin to an output.
- BYTE
Mode
| 0=Reset / 1=AsyncBB / 2=MPSSE / 4=SyncBB / 8=MCUHost / 16=FastOpto / 32=CBUS / 64=SyncFIFO
- BYTE
FT_SetRts
| This function sets the Request To Send (RTS) control signal.
| [[File:]] -
Handle
- BYTE
FT_GetDeviceInfoDetail
| This function returns an entry from the device information list.
- ULONG
Index
| Index of the entry in the device info list.
- ULONG
Flags
| Pointer to unsigned long to store the flag value.
- ULONG
Type
| Pointer to unsigned long to store device type.
- ULONG
ID
| Pointer to unsigned long to store device ID.
- ULONG
LocID
| Pointer to unsigned long to store the device location ID.
- BYTE
SerNum
| Pointer to buffer to store device serial number as a null terminated string
- BYTE
Descript
| Pointer to buffer to store device description as a null-terminated string
| [[File:]] -
TempHandle
| Pointer to a variable of type FT_HANDLE where the handle will be stored
- BYTE
FT_Close
| Close an open device.
| [[File:]] -
Handle
- BYTE
FT_ClrDtr
| This function clears the Data Terminal Ready (DTR) control signal.
| [[File:]] -
Handle
- BYTE
FT_Purge
| This function purges receive and transmit buffers in the device.
| [[File:]] -
Handle
| [[File:]] -
Mask
| Used to determine which buffer to purge, 1=Rx / 2=Tx / 3=Both
- BYTE
FT_GetQueueStatus
| Gets the number of bytes in the receive queue.
| [[File:]] -
Handle
| [[File:]] -
RxQueueLength
| Pointer to a variable of type DWORD which receives the number of bytes in the receive queue.
- BYTE
FT_SetDataCharacteristics
| This function sets the data characteristics for the device.
| [[File:]] -
Handle
- BYTE
WordLength
| Number of bits per word - Must be 7 or 8
- BYTE
StopBits
| Number of stop bits - Must be 1 or 2
- BYTE
Parity
| Parity 0=None / 1=Odd / 2=Even / 3=Mark / 4=Space
- BYTE
FT_SetBreakOff
| Resets the BREAK condition for the device.
| [[File:]] -
Handle
- BYTE
FT_SetDivisor
| This function sets the baud rate for the device. It is used to set non-standard baud rates.
| [[File:]] -
Handle
- UINT
Divisor
| Divisor.
- BYTE
FT_SetBaudRate
| [[File:]] -
Handle
- ULONG
BaudRate
| Baud rate.
- BYTE
FT_SetDtr
| This function sets the Data Terminal Ready (DTR) control signal.
| [[File:]] -
Handle
- BYTE
FT_Open
| Open the device and return a handle which will be used for subsequent accesses.
| [[File:]] -
Device
| Index of the device to open. Indices are 0 based.
| [[File:]] -
ft_Handle
| Pointer to a variable of type FT_HANDLE where the handle will be stored. This handle must be used to access the device.
- BYTE
ScanFor232
| Scans for a FTDI D2XX device, returnes true if at least one device was found.
| [[File:]] -
FT_ResetDevice
| This function sends a reset command to the device.
| [[File:]] -
Handle
- BYTE
FT_SetChars
| This function sets the special characters for the device.
| [[File:]] -
Handle
- BYTE
EventCh
| Event character.
- BYTE
EventChEn
| 0 if event character disabled, non-zero otherwise.
- BYTE
ErrorCh
| Error character.
- BYTE
ErrorChEn
| 0 if error character disabled, non-zero otherwise.
- BYTE
DrawRectangle
| Draws a rectangle with the current foreground colour from pixel loaction X1, Y1 to pixel location X2, Y2.
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
PixelColour
| 0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
| Resets and initialises the Internet E-Block. It sets up the gateway address, subnet mask, device IP address and device MAC address as defined in the properties of the Flowcode component. This macro must be called before any other TCP_IP component macros
MODPMSHAPE
| Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE
Shape
| Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
ARB4
| Loads the binary-data to an existing arbitrary waveform memory location ARB4.
- BYTE
Waveform
CLKSRRet
| Returns the clock source <INT> or <EXT>.
| [[File:]] -
MODPMDEV
| Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
| [[File:]] -
Degrees
| Sets PM waveform deviation in degrees (-360 - 360).
MSTLOCK
| Sends signal to SLAVE generator to get synchronised
HILVL
| Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
| [[File:]] -
HighLevel
| Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
ARB3
| Loads the binary-data to an existing arbitrary waveform memory location ARB3.
- UINT
Waveform
WAVE
| Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
- BYTE
WaveType
| 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
CALADJ
| Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
| [[File:]] -
Calibrate
| Adjust the selected calibration value (-100 - 100).
STBRet
| Returns the value of the Status Byte Register in <nr1> numeric format.
- BYTE
ARB2
| Loads the binary-data to an existing arbitrary waveform memory location ARB2.
- UINT
Waveform
EERRet
| Query and clear execution error number register.
- STRING
MODFMSRC
| Sets FM waveform source to; 0 INT, 1 = EXT.
| [[File:]] -
Source
| Sets FM waveform source (0 = INT, 1 = EXT).
MODAMFREQ
| Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
| [[File:]] -
Frequency
| Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
ESE
| Sets the Standard Event Status Enable Register to the value of <nrf>.
- BYTE
Value
| Value of register 0-255
ARB1
| Loads the binary-data to an existing arbitrary waveform memory location ARB1.
- UINT
Waveform
| 16 Bit binary number for arbitrary waveform.
ARB4DEFRet
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
- STRING
CLS
| Clears status byte register of the interface.
MSTRELOCK
| Resynchronises the two generators in MASTER-SLAVE mode.
NOISLVL
| Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
- BYTE
Percent
| Sets the output noise level in percent. (0 - 50)
LOCKMODE
| Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
- BYTE
Mode
| Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
ADDRESSRet
| Returns the instruments address
| [[File:]] -
MODPMSRC
| Sets PM waveform source to; 0 INT, 1 = EXT.
| [[File:]] -
Source
| Sets PM waveform source (0 = INT, 1 = EXT).
MODPWMSRC
| Sets PWM waveform source to; 0 = INT, 1 = EXT.
| [[File:]] -
Source
| Sets PWM waveform source (0 = INT, 1 = EXT).
MOD
| Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
- BYTE
Modulation
| Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
ISTRet
| Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
| [[File:]] -
LRNRet
| Returns the complete setup of the instrument as a binary data block
| [[File:]] -
OPCRet
| Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
| [[File:]] -
SWPTYPE
| Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
- BYTE
Type
| Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
PULSRANGE
| Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
- BYTE
Range
| Sets the pulse rise and fall range. (1, 2 or 3)
TSTRet
| The generator has no self test capability and the response is always 0 <rmt>.
| [[File:]] -
BSTTRGPOL
| Sets the burst trigger slope to; 0 = POS, 1 = NEG.
| [[File:]] -
Slope
| Set the burst trigger slope (0 = POS, 1 = NEG).
ARB3Ret
| Returns the binary-data from an existing abbitrary wavefrom memory location.
- UINT
BSTPHASE
| Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
| [[File:]] -
Degrees
| Sets the burst phase in degrees (-360 - 360)
IDNRet
| Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
- STRING
ReturnIDN
- STRING
SWPTRGPER
| Sets the sweep trigger period to <nrf> seconds
| [[File:]] -
Seconds
| Set the sweep trigger period in seconds.
PULSDLY
| Sets the waveform delay to <nrf> sec
| [[File:]] -
Sec
| Opens the COM port ready for communications.
| A text label for the component's panel component.
Simulations
