Author
Matrix Ltd
Version
2.1
Category
Wireless
Bluetooth (HC05 / HC06) component
Low level routines for controlling or interacting with a HC05 or HC06 Bluetooth module. Contains functions to allow the baud rate, bluetooth name and bluetooth key to be defined.
Example Program that configures a HC05 / HC06 Bluetooth module and then allows a data connection to be established and utilised.
Incoming data will be displayed on an LCD.
Outgoing data is assigned and sent using a keypad component.
HC05 Example
SetPairKey
Sets the Bluetooth pair key stored in the Bluetooth module's ROM. Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
- STRING
Key
Four digit pair key e.g. "0000" or "1234"
SendString
Sends out a string of bytes from the UART interface.
- STRING
Data
SendCommand
Sends a command string to the HC05/HC06 module.
- STRING
Command
SetBaud
Sets the Bluetooth baud rate stored in the Bluetooth module's ROM. Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
- BYTE
Baud
1=1200, 2=2400, 3=4800, 4=9600, 5=19200, 6=NA, 7=38400, 8=57600, 9=115200
SendNumber
Sends out a number as an ASCII String from the UART interface.
[[File:]] -
Number
SendChar
Sends out a single packet from the UART interface.
[[File:]] -
Char
SetName
Sets the Bluetooth Friendly name stored in the Bluetooth module's ROM. Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
- STRING
Name
Name you wish to provide to the module
ReceiveString
Attempts to receive a string of bytes from the UART interface.
- BYTE
Timeout
- BYTE
NumBytes
- STRING
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
ReceiveChar
Attempts to receive a single packet from the UART interface.
[[File:]] -
Timeout
Time to wait for valid data before returning, 0=Dont wait, 255=Wait forever.
[[File:]] -
Data Bits
Number of data bits
Return data width from Receive macro. 8-bit data mode always returns a byte ranging from 0-255, 255 could mean a timeout or could be a valid data. 16-bit data mode rereturns 0-255 for valid data, 256 for a timeout, return data must be stored into an INT or UINT variable.
Echo
Echo selection
Baud Options
Use TX
Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
TX
Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
RX
Use Flow Control
Simulations
Textual label shown on the component I/O flasher
Console Columns
Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
