Component: Heelight Sensor (Grove 101020312) (101020312) (Audio)
Revision as of 11:03, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Audio
Heelight Sensor (Grove 101020312) component
Heelight Sensor is a smart voice sensor that can recognize up tp 500 digital voice commands. It was originally used on the Heelight – a smart colorful bulb that can be controlled by digital sound waves. Allows you to realize smart control in your own projects. Compatible with Heelight smart phone apps and other Heelight controllers.
Fc9-comp-macro.png ReadData
Reads data received from the listen macro.
Fc9-u8-icon.png - BYTE Index
Data Byte Received Range: 0-3
Fc9-comp-macro.png ListenForCommand
Listens for a Heelight command with timeout. Returns 1 if a command received. Returns 0 if no command was received.
Fc9-u8-icon.png - BYTE Timeout
0=Don't Wait, 1-254=MilliSec Delay, 255=Wait Forever
Fc9-comp-macro.png Initialise
Sets up the UART peripheral ready to receive messages from the Heelight sensor.
Fc9-type-16-icon.png Channel
UART Channel selector
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Baud Options
Fc9-conn-icon.png Simulations
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
