Component: API (RPI) (API Slave Devices)
Revision as of 11:06, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API (RPI) component
Connects to a Raspberry Pi running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
The App Developer (RaspberryPi) component allows an Raspberry Pi to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Raspberry Pi hardware the board must first be pre-programmed with dedicated firmware.
The firmware file and Flowcode source project can be downloaded from here.
RPI App Developer Firmware
The IP Address to the Raspberry Pi hardware is selected via the SCADA_RPI component IP Address property.
When building the component into a App Developer project remember to expose the IP Address property to allow the end user to select the correct address for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
Device Port Pin G2 G3 G4 G5 G6 G7 G8 G9 G10 G11 G12 G13 G14 G15 G16 G17 G18 G19 G20 G21 G22 G23 G24 G25 G26 G27
App Developer Slave Peripheral Pin I2C SDA I2C SCL SPI MOSI SPI MISO SPI SCK UART RX UART TX PWM 0 PWM 1
Device Port Pin G2 G3 G10 G9 G11 G15 G14 G12 G13
I2CInitialise
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
IOGetInputPin
- BYTE Pin
Range: 0-29
[[File:]] - Return
UARTBaud
- BYTE Channel
- BYTE Rate
ADCSample8
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255
- BYTE ADCChannel
Range: 0-12
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
UARTInitialise
- BYTE Channel
UARTCheckRX
- BYTE Channel
I2CRestart
- BYTE Channel
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-1
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
[[File:]] - Last
I2CStop
- BYTE Channel
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
PWMSetDuty
- BYTE Channel
Range: 0-5
- BYTE Duty
ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-12
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
IOSetOutputPin
- BYTE Pin
Range: 0-29
[[File:]] - State
Range: 0-1
UARTReceive
- BYTE Channel
SPIInitialise
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Channel
- BYTE Prescaler
- BYTE Period
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-1
RPI IP Address
IP Address of the Raspbery Pi we want to control
RPI Port
Port number we want to communicate on. Default 1234
Network Interface
Some computers may have several network interfaces such as ethernet ports and wifi access. Select the correct network interface for the network you wish to connect to. Use the IP address to confirm you are connected to the right network.
IP Address
IP Address of the selected network interface.
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Console Log
Create an automatic console log of the commands sent to the Arduino
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
Simulations
