Component: Temperature Infrared (Grove 101020062) (Environmental)
Revision as of 11:06, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category Environmental
Temperature Infrared component
The Grove Infrared Temperature Sensor allows none contact measurement of temperatures ranging from -10 to 100 degrees C.
MeasureSurTemp
Measures the surrounding ambient temperature,
[[File:]] - Return
MeasureObjectTemp
Measures the temperature of the targetted object
[[File:]] - Return
Ambient Pin (SUR)
Object Pin (OBJ)
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Temperature Calibration
Ambient temperature calibration value
Temperature Range
Map of temperature-voltage according to sensor datasheet. 10 is the temperature step when sensor and object distance is 9CM.
Offset Voltage
Voltage of mid level voltage after 5-10 mins to bring the sensor to ambient.
Number of Samples
Number of samples to take to average out each reading. Default 10.
Simulations
