Author
Matrix Ltd
Version
1.4
Category
Graphical Monochrome
GLCD (KS0108) component
Graphical display component designed to work with the KS0108 type monochrome displays. Also compatible with the newer S6A0107 controller IC displays.
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
[[File:]] -
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Pixel_Colour
0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
Pixel_Colour
0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Pixel Width
Pixel Height
Controller Count
Speicifies the number of controller IC's built into the display and therefore the number of available chip select pins
Monochrome
Foreground Color
Background Colour
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Enable Delay
Time in micro seconds to wait before and after toggling the enable pin.
CS1
Chip select to address the first controller IC
CS2
Chip select to address the second controller IC
RS
Data / Instruction register select pin.
RW
Read / write select pin
Enable
Data enable to clock a command or data in or out of the device
Data0
Data Pin 0
Data1
Data Pin 1
Data2
Data Pin 2
Data3
Data Pin 3
Data4
Data Pin 4
Data5
Data Pin 5
Data6
Data Pin 6
Data7
Data Pin 7
Reset
Display reset pin
Simulations
