Component: Linear Actuator (Mechatronics)
Revision as of 11:10, 17 November 2021 by Wiki bot (talk | contribs)
Category Mechatronics
Linear Actuator component
Creates a linear actuator that can be used with the various motor components via a coupling or gearbox.
Rotate
Simulation Rotate function to allow accurate rotation during simulation. Automatically called by any attached coupling or gearbox component.
[[File:]] - Angle
Amount to rotate the shaft input in degrees
CheckLimits
Checks to see if either limit switch is active. Returns 1 if min switch is active, 2 if max switch is active, 3 if both switches are active else returns 0.
Translation Per Rev
Sets the amount of translation for each revolution of the input shaft. M4 = 0.7mm M5 = 0.8mm M6 = 1.0mm M8 = 1.25mm M10 = 1.5mm
Travel
Amount of travel in the linear actuator before hitting the end stops
Revolutions
Number of revolutions the actuator can travel
Colour
Sets the colour of the actuator and end stops
Limit Type
Controls if limit switches are available on the linear actuator.
Switch Polarity
Sets the active polarity of the input switches. Active low are often used to help reduce noise on the switch inputs.
Min Switch Pin
Pin connection used for the minimum limit switch
Max Switch Pin
Pin connection used for the maximum limit switch
Output
Output connection for example an end tool or another linear slide and motor group.
Output Offset X
Distance along the X axis from the center of the coupling to the center of the output object.
Output Offset Y
Output Offset Z
Distance along the shaft from the center of the coupling to the center of the output object.
Simulations
