| Author
Matrix TSL
| Version
1.5
| Category
LEDs
RGB LED SK6812 RGBW component
A simple chained RGBW LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Compatible with the SK6812 RGBW Type Controller ICs. Allows RGBW LEDs to be driven with full 24-bit colour depth plus 8-bit white channel. Allows single chains, 2D arrays and 3D cube formations to be simulated. Requires a high speed microcontroller to generate the critical timings to drive the device.
LED Resistor Calculator Tool
SetBrightness
| Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
| [[File:]] -
Scaler
| Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
GetLEDColour
| Sets the colour of a single LED in RAM as a 1D array.
- UINT
LED
| LED to change the colour / Range: 0 to (LED Count - 1)
- BYTE
ColIdx
| 0 = Red, 1 = Green, 2 = Blue, 3 = White
- BYTE
OutputLow
SetBrightnessByte
- BYTE
Scaler
| Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
Delay_T0L
DrawLine2D
| Draws a line on a 2D array of LEDs
- UINT
X1
| Start X Coordinate
- UINT
Y1
| Start Y Coordinate
- UINT
X2
| End X Coordinate
- UINT
Y2
| End Y Coordinate
- BYTE
R
| Red colour channel
- BYTE
G
| Green colour channel
- BYTE
B
| Blue colour channel
- BYTE
W
| White colour channel
OutputHigh
SetLEDColour
- UINT
LED
- BYTE
R
| Red Colour Channel
- BYTE
G
| Green Colour Channel
- BYTE
B
| Blue Colour Channel
- BYTE
W
| White Colour Channel
SetAllLEDColour
| Sets the colour of all the LEDs in RAM
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
| Blue Colour Channel
- BYTE
W
Delay_T0H
Delay_T1L
Refresh
| Clocks out the current colour data to the LEDs from the values stored in RAM
ShiftLEDs1D
| Shifts the LED colours in 1D and wraps
- BYTE
Direction
| 0 = Forwards, 1 = Backwards
- BYTE
DataMode
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
DrawLine3D
| Draws a line on a 3D array of LEDs
- UINT
X1
| Start X Coordinate
- UINT
Y1
| Start Y Coordinate
- UINT
Z1
| Start Z Coordinate
- UINT
X2
| End X Coordinate
- UINT
Y2
| End Y Coordinate
- UINT
Z2
| End Z Coordinate
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
| Blue Colour Channel
- BYTE
W
Delay_T1H
GetLEDIndex2D
| Sets the index of a single LED in RAM as a 2D array.
- UINT
X
| LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT
Y
| LED Row to change the colour / Range: 0 to (LED Row - 1)
- UINT
DrawRectangle2D
| Draws a basic 2D rectangle onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE
R
- BYTE
G
- BYTE
B
- BYTE
W
ShiftLEDs2D
| Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
| [[File:]] -
X
| Number of pixels to shift the display -1 to 1 / 0 = No Shift
| [[File:]] -
Y
- BYTE
DataMode
GetLEDIndex3D
| Gets the index of a single LED in RAM as a 3D array.
- UINT
X
- UINT
Y
- UINT
Z
| LED Layer to change the colour / Range: 0 to (LED Layer - 1)
- UINT
DrawCuboid3D
| Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
| Start X pixel coordinate
- BYTE
Y1
| Start Y pixel coordinate
- BYTE
Z1
| Start Z pixel coordinate
- BYTE
X2
| End X pixel coordinate
- BYTE
Y2
| End Y pixel coordinate
- BYTE
Z2
| End Z pixel coordinate
- BYTE
DrawStyle
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
- BYTE
W
| Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
ShiftLEDs3D
| [[File:]] -
X
| [[File:]] -
Y
| [[File:]] -
Z
- BYTE
DataMode
LED Controller
| Allows the user to select which LED controller IC they are using. The different controller ICs all work the same way but have different timing characteristics.
Data Order
| Configures the order the colour data is clocked out to the LEDs
Reset Time (uS)
| Blanking reset period to reset the LED shift chain and start from the beginning
T0H (uS)
| Logic 0 high time in microseconds
T0L (uS)
| Logic 0 low time in microseconds
T1H (uS)
| Logic 1 high time in microseconds
T1L (uS)
| Logic 1 low time in microseconds
LED Arrangement
| Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
LED Count
| Total number of LEDs in the design
Arrangement
| LEDs will likely be arranged in one of two ways. Parallel = Each row of LEDs run from left to right - easier to address but harder to wire. Alternating = Each row of LEDs runs in an alternating direction - harder to address but easier to wire.
Column Count
| Number of horizontal LEDs - X axis
Column Spacing
| X Spacing Between LEDs on the Panel
Row Count
| Number of vertical LEDs - Y axis
Row Spacing
| Y Spacing Between LEDs on the Panel
Layer Count
| Number of LED layers - Z axis
Layer Spacing
| Z Spacing Between LEDs on the Panel
Flip X
| Flips the X axis if the LEDs are wired from the right hand side of the display.
Flip Y
| Flips the Y axis if the LEDs are wired from the under side of the display.
Flip Z
| Flips the X axis if the LEDs are wired from the upper most side of the display.
Data Pin
| LED Data Pin - Connected to the Data In pin of the first WS821x IC.
Simulations
