Component: IoT Made Easy (Comms: IoT/Cloud)
Revision as of 13:28, 17 November 2021 by Wiki bot (talk | contribs)
Category Comms: IoT/Cloud
IoT Made Easy component
A component designed to simplify MQTT comms allowing for multiple data streams to be dealt with in a simple manner. Deals with translating values to and from the broker from topic strings into message IDs and numeric values. Works with lots of different MQTT brokers.
ErrorAsString
- BYTE Error
- STRING Return
PublishString
Publishes data to the selected topic ID using a data string. Returns none zero if successful
- BYTE TopicID
The topic ID to publish data to
- STRING Data
Data string to publish
GetTopicID
Compares the topic ID of the last received message with enabled IDs. Returns the topic ID received.
Connect
Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected.
GetPayloadInteger
Get the Payload of the last received (Read) packet as a signed long value
[[File:]] - Return
LastError
Returns the last error
Read
Read incoming data. Returns non-zero if packet received. Use GetTopicID and GetPayloadXXX to read the contents.
Disconnect
Disconnects from the MQTT server and the network
PublishFloat
Publishes data to the selected topic ID using a floating point value. Returns none zero if successful
- BYTE TopicID
- FLOAT Data
Data to publish
Ping
Ping packet is sent to the server and checks for a reply. If nothing is sent or received within the keep alive period then a ping is required to keep the connection to the server active. Returns non-zero value if successful
PublishInteger
Publishes data to the selected topic ID using a signed long integer value. Returns none zero if successful
- BYTE TopicID
[[File:]] - Data
Data to publish
GetPayloadFloat
Get the Payload of the last received (Read) packet as a floating point value
- FLOAT Return
GetPayloadString
Get the Payload of the last received (Read) packet as a string value
- STRING Payload
- BYTE Size
Starts up the MQTT component - call this after initialising the NetworkComms component.
Host
Address of MQTT Broker Can be an IP Address or URL (URL only supported by some hardware platforms)
Port
Port used by MQTT Broker Default 1883 for unencrypted access and 8883 for encrypted access.
Client identifier
Client identifier (Maximum length 20 characters) Must be unique to the broker.
Network Timeout
Maximum time in mS to wait for network responses
Read Timeout
Time to wait in ms when waiting for incoming messages
Keep Alive
The Keep Alive is the maximum time interval that is permitted to elapse between the point at which the Client finishes transmitting one Control Packet and the point it starts sending the next, measured in seconds.
Network Component
Pointer to the network communications component providing TCP simulation and abstraction for embedded TCP modules.
Authentication
Selects if the broker is open or if the broker requires a username and password.
Number of topics
Sets the number of data topics that can be sent or received
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Topic String
Topic Type
Simulations
