Component: Thermistor (Environmental)
Version | 1.1 |
Category | Environmental |
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. Default calibration is for the EBM003 module.
GetIntegerTemperature |
Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
Return |
SetChannel |
Set the ADC Channel | |
ChannelID |
Return |
SetMinMax |
Set the minimum and maximum temperature values that can be shown and set on the thermometer readout. | |
Min |
Minimum Value | |
Max |
Maximum Value | |
Return |
GetRealTemperature |
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
Return |
CalculateTemperature |
Converts the input ADC value and returns the Temperature in tenths of degree C | |
ADCValue |
ADC Reading to be converted | |
Return |
GetADCValue |
Returns the Raw ADC value from the Analogue Channel | |
Return |
