Component: Simulation External Input (Runtime Tools)
Revision as of 13:31, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category Runtime Tools
Simulation External Input component
A simulation only component designed to allow a single digital pin to be toggled at a set frequency. Allows things like switch presses or external square waves to be used with the simulation.
Fc9-comp-macro.png Control_Pulse
Controls if the toggle input is enabled or disabled allowing you to stop and start the waveform.
Fc9-u8-icon.png - BYTE State
0=Disabled, 1=Enabled
Fc9-comp-macro.png Get_Pulse_Count
Reads the number of pulses remaining in the current run. The Pulse Count property needs to have an initial value > 0 to switch on the pulse counting mode.
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png Set_Space
Overrides the component property setting allowing for a variable frequency input or adjustable Space timings.
Fc9-u16-icon.png - UINT Delay
Delay between transitiions in milliseconds.
Fc9-comp-macro.png Set_Pulse_Count
Overrides the number of pulses. The Pulse Count property needs to have an initial value > 0 to switch on the pulse counting mode.
Fc9-u32-icon.png - ULONG PulseCount
Number of pulses to output
Fc9-comp-macro.png Set_Frequency
Allows the frequency to be changed on the fly
Fc9-f32-icon.png - FLOAT Frequency
Fc9-comp-macro.png Set_Mark
Overrides the component property setting allowing for a variable frequency input or adjustable Mark timings.
Fc9-type-5-icon.png Pin
Pin to toggle - connected to the external waveform on the target hardware.
Fc9-type-16-icon.png Startup Mode
Controls if the pulses start when the simulation is started or when the simulation Control_Pulse macro is called.
Fc9-type-16-icon.png Mode
Fc9-type-15-icon.png Frequency (Hz)
Frequency to try and acheive.
Fc9-type-21-icon.png Period Delay (ms)
Delay in milliseconds for a whole period of 0 and 1.
Fc9-type-21-icon.png Mark Delay (ms)
Delay in milliseconds to wait to toggle the pin. Note that Windows can only acheive timings of 10ms or more.
Fc9-type-21-icon.png Space Delay (ms)
Fc9-type-21-icon.png Pulse Count
Number of pulses to output. 0 = Run forever. > 0 = Output the selected number of pulses
Fc9-conn-icon.png Simulations
