Component: GLCD (SH1106) I2C (Graphical Monochrome)
Revision as of 13:33, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.4
Category Graphical Monochrome
GLCD (SH1106) I2C component
Graphical display component designed to work with the SH1106 type monochrome displays. Transfers data using a 2-wire I2C interface.
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Write_Command
Fc9-u8-icon.png - BYTE Command
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-type-16-icon.png Display Method
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Fc9-type-16-icon.png API
Fc9-type-16-icon.png I2C Address Bit
I2C Address Bit - Bit 0 of the address and adjustable by the user.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-type-5-icon.png Reset
Display reset pin
Fc9-conn-icon.png Simulations
