Component: Injector (API Analog Input) (Test Injectors)
Revision as of 15:38, 17 December 2021 by Wiki bot (talk | contribs)
Version 1.2
Category Test Injectors
Injector (API Analog Input) component
Data injector to allow a physical analog input pin to be attached to a simulated component. The component will poll for any input state changes via SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly interface with a physical I/O pin.
InitialiseInjector
- STRING InjectorName
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
- HANDLE Return
API Slave
Number of Pins
Specifies the number of pins the component can monitor and control.
Poll Rate
Simulation ADC Pin
Pin monitored by the simulation
SCADA Slave ADC Pin
Pin used by the connected SCADA Slave hardware
Simulation ADC Pin
SCADA Slave ADC Pin
Simulation ADC Pin
SCADA Slave ADC Pin
Simulation ADC Pin
SCADA Slave ADC Pin
Simulation ADC Pin
SCADA Slave ADC Pin
Simulation ADC Pin
SCADA Slave ADC Pin
Simulation ADC Pin
SCADA Slave ADC Pin
Simulation ADC Pin
SCADA Slave ADC Pin
Simulations
