Component: Barometer (DPS310) (Environmental)
Revision as of 16:24, 7 January 2022 by Wiki bot (talk | contribs)
Category Environmental
Barometer (DPS310) component
A barometric air pressure sensor with high accuracy and low current consumption. Capable of sensing air pressure and temperature. Based on an I2C bus connection.
SENSORS
ReadTemperature
Reads the temperature measurement from the last SampleSensor macro
- FLOAT Return
ConfigurePressure
Configures the pressure sensor sample rate and over sampling count
- BYTE Rate
Range: 0-7, 0=1Hz, 1=2Hz, 2=4Hz etc
- BYTE Oversample
Range: 0-7, 0=1Samples, 1=2Samples, 2=4Samples etc
ConfigureTemperature
Configures the temperature sensor sample rate and over sampling count
- BYTE Rate
- BYTE Oversample
ReadPressure
Reads the pressure measurement from the last SampleSensor macro
- FLOAT Return
SetMode
Sets the operational mode of the sensor to be continous or one shot
- BYTE Mode
ReadAltitude
Reads the pressure measurement from the last SampleSensor macro and converts the pressure reading into an altitude reading.
- FLOAT Return
SampleSensor
Checks to see if new data is available for temperature or pressure and collects it. Returns 0 if no new data is available Returns 1 for pressure, 2 for temperature and 3 for both.
ReadRegister
Reads a byte from a register
- BYTE Address
WriteRegister
Writes a byte to a register
- BYTE Address
- BYTE Data
Starts up the I2C ready to communicate with the sensor. Sets the selected rates and operational mode. Returns 1 if the sensor has been found and initialised.
- BOOL Return
Device Address
Measurement Rate
Oversample Rate
Operational Mode
API
Specifies the API component on the panel to interact with to provide comms simulation.
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Simulations
Simulate Comms
No: Provides simulation using the panel component sliders. Yes: Communicates via an API Slave device to real world hardware, shows the results using the panel component sliders.
