Component: Bluetooth (ESP32 SPP) (Wireless)
Author | Matrix TSL |
Version | 1.0 |
Category | Wireless |
Bluetooth (ESP32 SPP) component
Bluetooth slave component designed to run on a ESP32 providing legacy SPP functionality. BT Legacy functionality must be switched on via the sdkconfig file.
The SPP legacy bluetooth mode must be enabled in the ESP32 config file to allow SSP to work. To do this open the sdkconfig file from the project build directory into a text editor.
Find this section in the file
CONFIG_BTDM_CTRL_MODE_BLE_ONLY=y
- CONFIG_BTDM_CTRL_MODE_BR_EDR_ONLY is not set
And change to this.
- CONFIG_BTDM_CTRL_MODE_BLE_ONLY is not set
CONFIG_BTDM_CTRL_MODE_BR_EDR_ONLY=y
For problems sending strings, please see this forum topic.
ReceiveByte |
Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured | |
Timeout |
Number of ms to wait for incoming data | |
Return |
SendString |
Sends a string to the Bluetooth serial connection | |
Data |
Data Array to send | |
Return |
CheckConnectionStatus |
Checks to see if the Bluetooth device is connected. Returns 1 if connected. | |
Return |
ReceiveCount |
Collects the number of bytes currently stored in the receive buffer. | |
Return |
SendArray |
Sends a byte to the Bluetooth serial connection | |
Data |
NumBytes |
Number of bytes to send | |
Return |
SendByte |
Data |
Return |
ReceiveString |
MaxBytes |
Max number of bytes to try and read within the time | |
Timeout |
Return |
Initialise |
Starts up the Bluetooth communications SPP service. | |
Return |
