Component: Colour Sensor (TCS3200) (Light)
Revision as of 16:23, 7 January 2022 by Wiki bot (talk | contribs)
Version 1.1
Category Light
Colour Sensor component
This board provides the ability to detect colours using the TCS3200 sensor. It will return RGB and W values, dependent on the colour of the object under test.
SENSORS
Fc9-comp-macro.png SetConfig
Sends the config data byte to the sensor using clock and data pins
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png SetLEDOn
Turn on the White LEDs
Fc9-comp-macro.png SetFrequencyRange
Dynamically change the sensor output frequency range to a new setting
Fc9-u8-icon.png - BYTE Freq
Percentage range (2,20,100)
Fc9-comp-macro.png GetFrequency
Samples and returns the sensor output frequency (Hz)
Fc9-comp-macro.png SetFilter
Dynamically change the sensor filter to RGB or W. Red = 0 Green = 1 Blue = 2 White = 3
Fc9-u8-icon.png - BYTE FilterColour
Filter Colour; Red = 0, Green = 1, Blue = 2 and White = 3
Fc9-comp-macro.png SetLEDOff
Turn off the White LEDs
Fc9-comp-macro.png Initialise
Initialise the sensor configuration as set by the component properties
Fc9-type-5-icon.png SDA
Pin used for sending serial configuration data to the sensor device
Fc9-type-5-icon.png SCL
Pin used as clock pin for sending serial configuration data to the sensor device
Fc9-type-5-icon.png Sensor Output
Pin used to monitor the output frequency from the light sensor
Fc9-type-16-icon.png Output Frequency Range
Initial sensor output frequency range selection. 100% 0-500KHz 20% 0-100KHz 2% 0-10KHz
Fc9-type-16-icon.png Filter Option
Initial filter selected
Fc9-type-16-icon.png LED Control
Initial White LED state
Fc9-type-16-icon.png Sample Time Period
Length of time period used to sample the sensor frequency (longer is more accurate)
Fc9-conn-icon.png Simulations
