Component: Indicator Gauge (Indicators)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.3 |
| Category | Indicators |
Indicator Gauge component
Simulation only round gauge/dial for SCADA applications. The range of values displayed is easily adjusted.
Please click here for the component source code: FC_Comp_Source_IndicatorGauge.fcfx
| GetValue | |
| Get the current scale value - this will be the most recent value set using "SetValue", or from the most recent mouse click if the component is in "Control" mode. | |
| SetValue | |
| Set the pointer to the given value on the scale. Returns the angle required to point at the given value. | |
| Value | |
| The value on the scale to move the pointer to. | |
| SetRange | |
| Set the minimum and maximum values of the scale | |
| Minimum | |
| Minimum value for the scale | |
| Maximum | |
| Maximum value for the scale | |
