Component: Temp / Humidity (HTS221) (Environmental)
Revision as of 17:47, 9 November 2022 by Wiki bot (talk | contribs)
Category Environmental
Temp / Humidity component
A temperature and relative humidity sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 3.5% Temperature Range = -40 - 120 Degrees C +/- 0.5 Degrees C
Please click here for the component source code: FC_Comp_Source_Humidity_HTS221.fcfx
ReadHumidityInt
Samples the humidity from the sensor and returns the relative humidity reading as a integer byte from 0 to 100
DataAvailable
Checks to see if new sensor data is available. Returns 0 if no new data is available. Returns 1 if new Temperature data is available. Returns 2 if new Humidity data is available. Returns 3 if new Temp and Humidity data is available.
ReadTemperatureInt
Samples the temperature from the sensor and returns the reading in degrees C as an integer from -40 to 120.
- INT Return
ControlHeater
Controls the in-built heater element to speed up sensor recovery time in case of condensation. Humidity and temperature cannot be read while Heater is active.
- BOOL Active
0 = Off (Sensor Reading Available) / 1 = On (Sensor Reading Disabled)
ReadHumidityReal
Samples the humidity from the sensor and returns the relative humidity reading as a float from 0.0 to 100.0.
- FLOAT Return
ReadRegister
Reads an 8-bit value from one of the registers onboard the sensor IC.
- BYTE Address
ReadTemperatureReal
Samples the temperature from the sensor and returns the reading in degrees C as a float from -40.0 to 120.0.
- FLOAT Return
WriteRegister
Writes a value to a register on the sensor IC.
- BYTE Address
- BYTE Data
Configures the I2C peripheral ready for communications.
Sensor Properties
Data Rate
I2C Properties
Address
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Sim Type
