Component: Thermocouple (MAX31855) (Environmental)
Version | 1.0 |
Category | Environmental |
Thermocouple component
Component to interface the MAX31855 IC from MAXIM. Uses a standard 3-wire SPI interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Please click here for the component source code: FC_Comp_Source_ThermocoupleMAX31855.fcfx
Example program showing how to use the Thermocouple component.
MAX31855_Example
ReadReference_Int |
Returns the reference temperature from the last sample as an integer value in Degrees C. | |
Return |
ReadReference_Float |
Returns the reference temperature from the last sample as a floating point value in Degrees C. | |
Return |
Sample |
Reads the memory of the MAX31855 IC and checks for errors. Must be called before any of the Read functions. Returns: 0=OK, 1=Open Circuit, 2=Short GND, 3=Short VCC | |
Return |
ReadThermocouple_Int |
Returns the thermocouple temperature from the last sample as an integer value in Degrees C. | |
Return |
ReadThermocouple_Float |
Returns the thermocouple temperature from the last sample as a floating point value in Degrees C. | |
Return |
Initialise |
Configures the SPI bus ready for communications. | |
Return |
