API Panel.Position.Set
Revision as of 15:42, 15 May 2013 by (username removed)
<sidebar>API contents</sidebar> Sets an objects position based on a component or pre-defined position
Class hierarchy
Panel
Position
Set
HANDLE Dest
HANDLE Source
The position or component to read from
  • Add to a calculation icon:
    ::Panel.Position.Set(dest, source)
Flowcode example file
From the SimulationAPIExamples folder load SIMAPI_Panel_Position_Set.fcf file into Flowcode. In this example, The screenshots below show the effect and also highlight the code used by the example.
SIMAPI Panel Position Set Pic1.pngSIMAPI Panel Position Set Pic2.png SIMAPI Panel Position Set Pic0.png
