Component: Webserver (WIZ810MJ) (Comms: Networking)
Revision as of 17:52, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Comms: Networking
Webserver component
Webserver component designed to work with the WIZ810MJ module from Wiznet, as used in the version 2 EB023 E-block and MIAC System Industrial Addon. Provides a very simple interface to allow webpages to be hosted from hardware or simulation.
Please click here for the component source code: FC_Comp_Source_WebServer_EB023-00-2.fcfx
WM_CH_MR
- BYTE ch
WM_CH_PORT
- BYTE ch
WM_TXMEM
- BYTE ch
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
WM_CH_RX_RSR
- BYTE ch
MIAC_Module_GetData
- BYTE Index
SetOutValue
- BYTE index
- STRING value
Send_Embedded_HTML_Page4
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page2
WM_CH_IR
- BYTE ch
Send_Embedded_HTML_Page1
GetInValue
- BYTE index
- STRING Return
MIAC_Module_PushData
- BYTE Data
CreateServerSocket
Creates a listening socket on the selected channel and port ready to accept incoming web page requests.
- BYTE Channel
- UINT Port
WM_CH_CR
- BYTE ch
WM_CH_TX_WR
- BYTE ch
IncRxPtr
- BYTE Channel
CheckSocketActivity
Checks for activity on the server socket and serves out the webpages to any requesting parties.
WM_CH_SR
- BYTE ch
WM_RXMEM
- BYTE ch
HTML Source
Max Pages
Maximum number of pages we can serve using the embedded page type webserver.
Name Page 1
Name of HTML page 1 - index.htm is the default page that will be presented.
HTML Page 1
Embedded HTML code used for page 1
Name Page 2
Name of HTML page 2
HTML Page 2
Embedded HTML code used for page 2
Name Page 3
Name of HTML page 3
HTML Page 3
Embedded HTML code used for page 3
Name Page 4
Name of HTML page 4
HTML Page 4
Embedded HTML code used for page 4
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Int Pin
Interrupt pin connection on Wiznet module
Gateway IP
Gateway0
IP address of the gateway to the internet if applicable.
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet mask of the server - usually 255.255.255.0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP address of the server - usually 192.168.0.x or 192.168.1.x
IP1
IP2
IP3
MAC Address
MAC0
MAC address of the server
MAC1
MAC2
MAC3
MAC4
MAC5
Substitutions
Outgoing
Count
Length 0
Length 1
Length 2
Incoming
Count
Length 0
Sim Type
Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / API - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
TCP Simulation
Network Interface
List of network interfaces connected to the PC. Sets which interface we are communicating via.
