Component: LCD I2C (LCM1602) (Alphanumeric)
Revision as of 17:48, 9 November 2022 by Wiki bot (talk | contribs)
Category Alphanumeric
LCD I2C (LCM1602) component
Generic alphanumeric LCD display based on the standard Hitachi HD44780 controller IC. Connected using an I2C based PCF8574 IO Expander IC.
Please click here for the component source code: FC_Comp_Source_LCD_I2C_LCM1602.fcfx
Fc9-comp-macro.png Clear
Fc9-comp-macro.png PrintString
Enter the text or variable to print to the LCD
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Values 0 to 7
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
The line to clear, zero being the first (top) line of the display
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Set the cursor position in the X plane, 0 is the left most cell
Fc9-u8-icon.png - BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE Position
Holds the number of positions to shift the display
Fc9-u8-icon.png - BYTE Direction
0 = left, 1 = right
Fc9-comp-macro.png RawSend
Sends data to the LCD display
Fc9-u8-icon.png - BYTE data
The data byte to send to the LCD
Fc9-bool-icon.png - BOOL type
A boolean to indicate command type: true to write data, false to write a command
Fc9-comp-macro.png Backlight
Controls the backlight on the display module
Fc9-u8-icon.png - BYTE Mode
0 = Backlight Off / 1 = Backlight On
Fc9-comp-macro.png RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
Fc9-u8-icon.png - BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
Fc9-u8-icon.png - BYTE SearchCharacter
Character to look for a replace
Fc9-u8-icon.png - BYTE ReplacementCharacter
New character value to use in place of the search character.
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-21-icon.png SlaveAddress
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Display Settings
Fc9-type-16-icon.png Rows
Number of lines of characters the LCD can display.
Fc9-type-16-icon.png Columns
Number of characters the LCD can display on a single line.
Fc9-type-21-icon.png Remap Characters
Used to allow characters to be replaced with alternate characters. Custom characters or characters from the LCD memory map can be used as replacements. Each replacement consumes two bytes of RAM memory and is applied automatically when printing strings.
Fc9-type-21-icon.png Delay Timings
Delay in microseconds used in the display send function. Most displays will work with the default value of 100us. Some displays may need a slightly longer delay, 166us is known to work well.
Simulation only background colour, the actual hardware will have a fixed colour
Fc9-type-1-icon.png Line Color
Simulation only line colour, the actual hardware will have a fixed colour
Fc9-type-1-icon.png Text Color
Simulation only text colour, the actual hardware will have a fixed colour
Fc9-type-3-icon.png Font
Font to use for simulation, the actual hardware will have a inbuilt fixed font.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
