Component: RGB LED LP5030 LP5036 (LEDs)
Version | 1.0 |
Category | LEDs |
RGB LED LP5030 LP5036 component
An I2C Based RGB LED driver with 30 or 36 individual constant-current sinks. Used to drive 10 or 12 RGB LEDs with a wide range of applications.
Please click here for the component source code: FC_Comp_Source_LP5036_RGB_LED.fcfx
GetRGB |
Gets the RGB colour of a single LED. | |
Address |
Range: 0-11 | |
RGB |
Byte array containing at least 3 bytes to store Red, Green and Blue | |
Return |
ReadReg |
Reads the data from one or more sequential registers | |
Address |
Data |
Count |
Return |
WriteReg |
Writes data to one or more sequential registers | |
Address |
Data |
Count |
Return |
SetRGB |
Allows the colour of a single LED to be specified in RGB. | |
Address |
Range: 0-11 | |
RGB |
Byte array containing at least 3 bytes to set Red, Green and Blue | |
Return |
GetBrightness |
Gets the brightness of a single LED. | |
Address |
Range: 0-11 | |
RGB |
Return |
SetUnitAddress |
Allows the component to taklk to more then one IC or broadcast to all connected ICs. | |
Address |
Range: 0-3 = Individual / 4 = Broadcast | |
Return |
Initialise |
Starts up the I2C comms ready for communicating with the LP503x module. Must be called before any of the other component macros are called. | |
Return |
