Component: PWM 16CH 12Bit (PCA9685) (General Output)
Version | 1.0 |
Category | General Output |
PWM 16CH 12Bit (PCA9685) component
The PCA9685 is an I²C-bus controlled 16-channel LED controller optimized for Red/Green/Blue/Amber (RGBA) color backlighting or Servo motor applications. Each output has its own 12-bit resolution (4096 steps) fixed frequency individual PWM controller that operates at a programmable frequency from a typical of 24 Hz to 1526 Hz. All outputs are set to the same PWM frequency. Up to 64 devices can be chained together on a single I²C-bus to provide up to 1024 individual PWM outputs.
Please click here for the component source code: FC_Comp_Source_PCA9685_16_Channel_PWM.fcfx
Reset |
Sends a reset command to the PCA9685 chip over I2C | |
Return |
SetPWMFrequency |
Sets the PWM frequency for the entire chip, up to approx 1.6 KHz | |
Frequency |
Floating point frequency that we will attempt to match | |
Return |
Sleep |
Puts the module into Sleep mode | |
Return |
SetExternalClock |
Sets EXTCLK pin to use the external clock | |
Prescale |
External Clock Prescaler - Range: 3-255 | |
Return |
SetAddress |
Allows a different I2C address to be specified allowing one component to control multiple PCA9685 modules. | |
Address |
Range: 0x40 - 0x7F | |
Return |
SetClockFrequency |
Sets the current clock frequency, used for things like calculating the PWM frequency and Microsecond duty. | |
Clock |
Return |
GetClockFrequency |
Returns the current clock frequency | |
Return |
Initialise |
Sets up the I2C ready for communications to begin | |
Return |
WakeUp |
Wakes the module from Sleep mode | |
Return |
